Quantcast steering play in cj5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > steering play in cj5
Genuine Italian leather shift boots for your Jeep!Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 08-24-2006, 10:53 PM   #1
rajarch
how much play should there be in the steering between the steering wheel and the steering gear for a 1975 cj5? I can turn the steering rod 1/8 to 1/4 turn before the gear is engaged, and it feels sloppy when I drive it - is this normal?
rajarch is offline   Reply With Quote
Old 08-25-2006, 12:05 AM   #2
SQF1
1976 CJ5
Mine has no play in the wheel at all. I have about a 1/4" play between the shaft and the gearbox. I would say a 1/4 turn of the shaft is a lot of play that shouldn't be there.
SQF1 is offline   Reply With Quote
Old 08-25-2006, 01:29 AM   #3
dirtbagofva
2010 JK Wrangler
mine has a lot of play in the stearing shaft (bad joints) I ordered one for 140 shipped. I found the Rusty's Offroad to be the least expensive. As for the play, check any other vehicle...almost no play.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline   Reply With Quote
Old 08-25-2006, 04:36 AM   #4
solitudetree
You need to check out all the components of your front end. Steering shaft, tie rod, drag link, ball joints, etc. Those can all contribute to the play you have.
You may want to consider upgrading the steering shaft for a heavy duty version like the one Borgeson's makes. The standard shaft just isn't strong enough for lifts and bigger tires. It will allow play to develop much sooner than a heavy duty shaft will.
[COLOR=DarkGreen][FONT=Century Gothic]All the Jeeps I've owned
79 CJ5 258 six with a weber (current vehicle) T18/Dana20
81 CJ5 258 six (driven out of Alaska thru Canada in winter with a softtop)
75 Jeep Wagoneer 360V8
79 Jeep Cherokee 258 six
[/FONT][/COLOR]
solitudetree is offline   Reply With Quote
Glock Forum
