Quantcast Steering Play - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Steering Play
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 08-26-2006, 08:14 PM   #1
Skavdog
Steering Play
I am getting some serious "play" in my steering. Can anyone offer up some ideas on how to get tighten it up a bit and if we're talking parts, what could I expect to be spending on this? Thanks, Skavdog
Skavdog is offline   Reply With Quote
Old 08-26-2006, 09:06 PM   #2
CJ Fanatic
I would start by having someone turn the steering wheel left to right, just through the range of play, as you watch the steering shaft between the column and steering box. If your slack is in the joints on the shaft, replace it. I bought a flaming river shaft for mine. It's awesome. If things look O.K. there, proceed to watch the shaft in relation to movement of the pitman arm. If there is slack present there, use the adjustment nut on top of the steering box to correct it if possible. Refer to a manual for this. If that looks O.K. check for wear on tie rod ends and movement of the steering box on the frame. These all are problem areas. If you look at my signature, I have addressed most of these areas on my CJ. Good luck.
A closed mouth gains no foot.
1977 CJ5, '75 258, Motorcraft 2150 carb, HEI dizzy, BDS 2.5" suspension, 3/4" Daystar Rock Krusher Greasable shackles, M.O.R.E. steering brace, Flaming River steering shaft, Tie rod flip, Yukon AMC20 axle kit, 1.5" Trail Sport wheel spacers, 15x10" Black Cragar soft 8s w/ 33" Yokohama Geolander MTs, Goodridge SS brake lines, Classic Tube stainless hard lines, YJ power brake with front disc upgrade (had 4 wheel drums)
CJ Fanatic is offline   Reply With Quote
Old 08-26-2006, 09:10 PM   #3
wwhitby
1979 CJ5
Check out your body mount bushings as well. I have been getting a lot of play in my steering, and I discovered most of it was caused by the body mount bolt and bushing under the radiator having fallen out.
Warren
Warren Whitby
1979 CJ-5 "Big Blue"
Real Jeeps have rust
Just Empty Every Pocket
wwhitby is offline   Reply With Quote
Old 08-27-2006, 06:50 AM   #4
Skavdog
thanks for the info, will start checking all these things out. Skavdog
Glock Forum
