Quantcast Steering Play - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Steering Play
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 05-19-2005, 12:28 PM   #1
Dimension4
Steering Play
Hi, I got my jeep running now but I seem to have some play in the steering. It kind of jitters all around when I'm going down the road, it gets worse as I get above 50-55 mph. I don't really know what is wrong, any suggestions?
Dimension4 is offline   Reply With Quote
Old 05-19-2005, 12:44 PM   #2
jeepskate
Check everything from the steering column on down/out...search...this has been covered multiple times...
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Old 05-19-2005, 02:58 PM   #3
Dimension4
I remember somebody had a bearing that was worn out, but I can't find the thread, what was that about.
Old 05-19-2005, 03:28 PM   #4
Geer_hed
besides wheel bearings, this thread has some good suggestions.
[center][color=black][b]85 CJ7 / 258 / T176 / Dana 30/ AMC 20[/b][/color]
[url=http://www.geocities.com/cantwait_forviolence/]My Online Dumping Ground[/url][/center]
Geer_hed is offline   Reply With Quote
Old 05-20-2005, 09:39 AM   #5
Mud Machine
Jeep Addict
Mud Machine's Avatar
Check the lower end of your steering column. Grab the steering shaft and give it a shake back and forth. If it is loose you found your problem. There is a bushing inside the lower steering column that is a very common wear item. You can find a rebuild kit for this on eBay if you search "Jeep steering column". The price isn't bad for this kit. I was not able to find the rebuild kit anywhere else including the dealer and auto parts stores. Hope this is the problem because it is an easy fix. Good luck.
GR8 Half Top Conversion Thread
Does your gas tank overflow at the pump?
SUBMIT FORMAL COMPLAINT HERE!
2005 Rubicon LJ Unlimited - 4 1/2" BDS Suspension - 285/75/16 Toyo M/T's - 12,000# Winch - Ground Pounder Fab Rear Bumper - FabRieckAtions Custom Front Bumper - Overkill Engineering Tube Fenders - GR8 Half Top - Rock Hard Cage - Banks Monster Exhaust - 5.13 Gears - High Performance Flux Capacitor
1976 CJ-7 - 33" Super Swampers - BDS 4" Suspension - 6 Point Roll Cage
Mud Machine is offline   Reply With Quote
Old 05-20-2005, 02:21 PM   #6
Fropleyqk
Nom Nom Nom
Fropleyqk's Avatar
Also, there's a little screw you can adjust on top of the steering box. Small adjustments at a time.
Fropleyqk is offline   Reply With Quote
Old 05-20-2005, 04:00 PM   #7
ollietonk
I had a similar problem. What are you running for lift, tires, and shackels? Is it still stock? I had to shim my from axle to get the caster back to normal due to the longer shackels. Just a thought.
86' CJ7 (258 w/ Howell TBI, 33" ProComp MT's)
ollietonk is offline   Reply With Quote
Glock Forum
