Steering Not Responsive. - JeepForum.com
post #1 of 8 Old 10-23-2009, 11:04 AM Thread Starter
as71977
So, after buying the CJ I had to drive it home and found a few issues that I really need to jump on pretty quick.
One of the problems is that the steering is not very responsive, I have to almost turn the wheel a quarter turn before getting any response.
This might sound like a dumb question but is that normal for a CJ7 or is there something I should be looking at to correct the poor response?
as71977 is offline
post #2 of 8 Old 10-23-2009, 11:20 AM
sanddrag
Get the front end up on jack stands, and have a friend turn the wheel back and forth while you take a look underneath. Should be pretty quick to observe the relative motion of things, and if anything is loose. Grab the tires and give them a wiggle too. And particularly, take a look at where the steering box is mounted to the frame. That area will crack sometimes.
sanddrag is offline
post #3 of 8 Old 10-23-2009, 11:23 AM
Mike Romain
No, that isn't right, there should be minimal slop in the wheel.
Basically I use a second person turning the wheel side to side and then I start looking at the first u-joint at the firewall on the column, then the second one at the bottom, then the pitman arm, then the tie rod ends for slop.
You may have a few places that need replacing.
Mike
Mike Romain is offline
post #4 of 8 Old 10-23-2009, 11:34 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Mine had a lot of slop in the manual gear box - you could watch the pitman shaft move up/down when you turned the wheel. Adjusted it to where I had only 3" side-to-side of the steering wheel compared to the 1/4 that was in it before. Then when I got the power steering installed the newer box was nice and tight, so I'd over-correct and swerve a lot. Surprised I didn't get pulled over that night!
Rick
Cutlass327 is offline
post #5 of 8 Old 10-23-2009, 11:48 AM Thread Starter
as71977
Thanks for the input. I kinda figured that might be the case but wanted to make sure that it wasn't designed that way. You know, designed to allow some slip when offroading. Now I will definitely get under there to check it out.
Don't want to go so long that I start to over steer after I get it fixed lol...
as71977 is offline
post #6 of 8 Old 10-23-2009, 06:04 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
I'm betting it's the stock steering box brackets. Mine was so worn out the steering box moved almost 1" from side to side before the wheels would start turning.
I ended up getting one of those heavy duty aftermarket ones made out of 3/8" steel.. best money I ever spent. Not only is it 10x stronger, it was 10x easier to install than the factory brackets..
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #7 of 8 Old 10-23-2009, 08:25 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Yeah, after watching mine flex as I was watching the new p/s system work, I'm thinknig I'll be doing some upgrades on the bracketry and maybe one of those supports that reach across to the other frame rail from the box.
Rick
post #8 of 8 Old 10-23-2009, 11:05 PM
NelsonATC
1980 CJ7
Check the "universal joint" on the steering shaft as well. This is most likely another area of slop
Mike
1980 CJ7
NelsonATC is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Coupler connecting steering gear to steering shaft is leaking? Natto123 Jeep CJ Forum 1 06-29-2008 12:52 PM
Trouble removing steering gear from steering shaft.... Natto123 Jeep CJ Forum 5 06-29-2008 10:56 AM
Size of the nut for steering column to hold steering wheel supraman1990 Jeep CJ Forum 4 02-07-2008 06:16 PM
