Steering knuckle ball stud - JeepForum.com
post #1 of 9 Old 12-06-2006, 01:33 PM Thread Starter
Indy
Indy's Avatar
I buggered up a couple treads on my steering knuckle top ball stud. Local shop is quoting about $70 just for the part and $30'ish for the install. Just me, or is that part cost really really high?
*edit
And am I really really crazy, or do people at alignment shops not know what a steering knuckle and ball stud are? I'm going to have to take the thing around town and show them the part.
I'm the only gay eskimo.
Indy is offline
post #2 of 9 Old 12-06-2006, 04:45 PM
Shameless Elmer
83 CJ5
1983 CJ5
If the only thing wrong is that the threads are messed up why not just chase the threads with a die? Your local auto parts store might loan you one. If not take it to any machine shop. If they don't do it for free, it shouldn't be more than a couple of bucks.
Shameless Elmer is offline
post #3 of 9 Old 12-06-2006, 10:54 PM
jeepskate
Alignment shops don't take that stuff apart. They just check the alignment and correct it if it's something minor like toe in/out. Might help if you called it a ball joint.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #4 of 9 Old 12-07-2006, 08:10 AM Thread Starter
Indy
Indy's Avatar
Good ideas, ty.
Indy is offline
post #5 of 9 Old 12-08-2006, 11:09 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
ball joints, both sides, top and bottom for me came in around $75.00, so 70 for just the top on one side seems a bit high, although if they are only going to charge you 30 bucks to take the whole thing apart, press out the old one, put the new one back in and then ptu it all back together, that seems kind of on the low side.
It will take at least an hour to get it all apart and back together, not to mention pressing in/out.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #6 of 9 Old 12-08-2006, 02:02 PM Thread Starter
Indy
Indy's Avatar
That's the thing. I've got the knuckle sitting in my truck, all it needs is the stud pressed out and the new one pressed in. Seems like a 5 minute job to me, I just don't have a press.
Indy is offline
post #7 of 9 Old 12-08-2006, 02:15 PM
certifiablejeep
Bicentennial Nickel
1976 CJ5
put it in a vice and hammer it out with a big punch, that works for me most of the time.
As for this next step, I have never done it, but I read somewhere that you can put the ball joint in the freezer and heat up the knuckle and the 2 can push in together or something like that. I remember reading it here or on some other forum for some cheap fixes. Not sure if it will work or not, but just a thought.
Again, I think it would need to be very cold and very hot in order for it to just slip in, but who knows...
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #8 of 9 Old 12-08-2006, 02:42 PM
jeepskate
There *are* ball joint/u-joint service kits you can get from Harbor Freight and the like for around $50-60. Obviously longer and harder than using a press, but it does work. I did one knuckle with it (you should replace both the upper & lower ball joints while you have the knuckle off...just good sense) then went over to Harbor Freight the next time they had a sale and picked up a 20 ton press for around $170-180...makes me almost as popular as the guys with welders: ball joints, u-joints, t-case gears, diff gears, 1-piece axle installs, etc. I just use the manual kit for the various fittings now and carry it on the trail.
post #9 of 9 Old 12-08-2006, 03:53 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
cb
that works on anything with a tapered-pressed fit..Freezing the ball joint will shrink it and heating the knuckle will expand it...Slip it in quickly and maybe a whack of a hammer and it should be good..you just have to work fast..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
Steering Knuckle removal problem 2002fordgt Jeep CJ Forum 5 06-03-2009 11:38 PM
How do you pack a steering knuckle with grease? part.changer Jeep CJ Forum 12 09-03-2007 05:47 PM
Dana 30 Steering Knuckle ball joint style kappa505 Jeep CJ Forum 0 12-21-2006 09:28 PM
Removing ball joints for knuckle swap Blthomas Jeep CJ Forum 8 06-28-2006 02:14 PM
Ball Stud replacement CJ7Jeff Jeep CJ Forum 4 08-19-2002 09:44 AM
