Steering Issue w/ Symptoms - JeepForum.com
post #1 of 25 Old 08-18-2011, 11:12 AM Thread Starter
cjkcj7
1983 CJ7
I did a search on JF, but didn't find anything that matched what I have.
Here are the symptoms: SOMETIMES when I turn left, I'll feel some resistance in the steering, then it pops and the steering wheel will continue to turn. Then my steering will be EXTREMELY sloppy to the point of white knuckles. After I shut the jeep down, the steering will be fine.
When I crawled under it, it didn't look like anything is binding. I have a 2.5" lift kit and my tires are 31X10.5. I have had the lift kit and these sized tires since 1998 with no steering issues.
Where should I be looking? Could the steering box be on its last legs?
Any help is appreciated.
1983 Jeep CJ7 Laredo 4.2/258 I6 T5 Transmission Dana 300 Transfer case Nuttered 2.5" Skyjacker lift
Custom front/rear bumpers
cjkcj7 is offline
post #2 of 25 Old 08-18-2011, 06:36 PM
gojeepin
1983 CJ7
Based on what you described, it could be the steering box BUT...
When you find out where the pop is coming from you'll know. You need to recreate the condition when somone is in a position to detect the sound.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 25 Old 08-18-2011, 06:58 PM
ODGREEN4X4
steering
Sounds like a reg cj to me - the white knuckle part ! Anyway is your steering stabalizer ( great spelling) bent or binding. its the left turn part that gets me. (nascar edition box ?) Check
1 .steering wheel splines
2. steering box splines
3 condition of u joints on shaft
4.wheel bearings
5 brakes binding
6 steering box arm (loose)
7 steering box -my guess.
This is most of the things i would check.
ODGREEN4X4 is offline
post #4 of 25 Old 08-18-2011, 07:00 PM
ODGREEN4X4
Is it power steering?
post #5 of 25 Old 08-18-2011, 07:10 PM
gojeepin
1983 CJ7
4.wheel bearings
5 brakes binding
True. Most of the time that works but you're describing an inspection of the vehicle at rest.
There are some times that you can only detect a problem when you create the condition that causes it.
gojeepin is offline
post #6 of 25 Old 08-18-2011, 07:19 PM
John N
1981 CJ8
Sounds like a siezed axle u-joint to me.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #7 of 25 Old 08-18-2011, 07:26 PM Thread Starter
cjkcj7
1983 CJ7
Yes it is. The fluid level is correct and there are no leaks.
Thanks for the replies so far.
cjkcj7 is offline
post #8 of 25 Old 08-18-2011, 07:27 PM Thread Starter
cjkcj7
1983 CJ7
How would I go about checking for that?
cjkcj7 is offline
post #9 of 25 Old 08-18-2011, 08:15 PM
brownbagg
1930 MK Compass
how about caster shims
brownbagg is offline
post #10 of 25 Old 08-18-2011, 08:26 PM
Matt_G
1979 CJ5
have you adjusted the box at all? there is an allen head on top that you can adjust the box with, be careful though, it is easy to mess things up.
"This isn't mud, it's a special Jeep Wax"
Matt_G is offline
post #11 of 25 Old 08-19-2011, 04:43 AM
keith460
Jeep. There's Only One
keith460's Avatar
Same here or it could be the upper and lower ball joints too.
Jack the front end off the ground so both tires are off the ground and support with jack stands.
Remove tires.
Put key in ignition so steering wheel is not locked.
Grab the brake rotor and push and pull so the axle knuckles turn left and right.
Listen for your popping noise.
Feel for abnormal resistance while pulling and pushing the rotor back and forth.
Check for binding in the axle U-joints and steering knuckle ball joints.
1984 CJ-7 Renegade
keith460 is offline
post #12 of 25 Old 08-19-2011, 07:10 AM Thread Starter
cjkcj7
1983 CJ7
No, I've never done anything to it.
cjkcj7 is offline
post #13 of 25 Old 08-20-2011, 06:29 PM Thread Starter
cjkcj7
1983 CJ7
Remove tires.
Keith 460 - I did as you said. I couldn't move the rotor back and forth. There was no play/movement at all. Is that normal?
Also, is the axle u-joint supposed to have a grease fitting? Mine do not.
Thanks again for help.
cjkcj7 is offline
post #14 of 25 Old 08-20-2011, 08:35 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Oh ya........ The cure all shims will make the resistance in the steering, the popping, the continue to turn steering wheel & the EXTREMELY sloppy steering
problems all disappear...................
LT1CJ7 is offline
post #15 of 25 Old 08-20-2011, 09:05 PM
keith460
keith460's Avatar
No, that's not normal and I would suspect worn and dried out upper and lower steering knuckle ball joints. I had a similar problem with my CJ years ago that steering was always a fight to keep straight down the road. Since the the ball joints were binding, the Jeep would wander or 'lock' to the left or right each time I made a correction in the steering to keep it straight. What a PIA that was and after raising the front end off the ground and removing the tires, I confirmed the ball joints were bad just by not being able to swing the knuckles back and forth from left to right and right to left.
After replacing all my ball joints, I was able to grab the brake rotor and turn the knuckle back and forth with some resistance. I also replaced the U-joints in the axle steering knuckles too since these can and will contribute to wandering steering also.
Some U-joints come with grease fittings and are usually the aftermarket ones and not OEM factory. I would first change the steering knuckle U-joints first since they will be the cheapest and easier to do then ball joints.
1984 CJ-7 Renegade
keith460 is offline
Issue w/ Steering box/shaft/steering wheel alignment. SuperSportCJ Jeep CJ Forum 6 01-18-2016 08:24 PM
What are the symptoms of steering box going out Dborns Jeep CJ Forum 7 07-04-2011 11:18 AM
Steering issue...Power Steering seems too good!! 76CJ5NGA Jeep CJ Forum 12 05-25-2009 09:48 AM
Steering box issue onexone Jeep CJ Forum 1 02-17-2009 06:52 PM
Steering issue Fropleyqk Jeep CJ Forum 4 06-12-2005 07:27 PM
