Steering issue...Power Steering seems too good!! - JeepForum.com
post #1 of 13 Old 05-24-2009, 11:45 AM Thread Starter
76CJ5NGA
1976 CJ5
On my 76 CJ5 the steering seems very...I mean very easy to turn. There is no play in the wheel. IMO at over 35mph it is unsafe. How do I make it more difficult to turn the wheels?? So I can keep it straight easier..
76CJ5NGA is offline
post #2 of 13 Old 05-24-2009, 11:50 AM
Coiz
1979 CJ7
Do you have a lift? If so, what kind? Assuming your base steering and suspension components are in good shape it could be a caster issue. Lack of positive caster will make the steering very easy and make the Jeep darty while driving. This gets worse with increased speed.
Mike
Coiz is offline
post #3 of 13 Old 05-24-2009, 11:53 AM Thread Starter
76CJ5NGA
1976 CJ5
Yeah it has a 4 " suspension lift on 35's.
76CJ5NGA is offline
post #4 of 13 Old 05-24-2009, 12:46 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
You need to make sure the caster is ok - wrong caster will allow it to drift easily.
Search for the Death Wobble..
Rick
Cutlass327 is offline
post #5 of 13 Old 05-24-2009, 01:02 PM
scottymac62
1979 CJ7
You will need to check your toe-in alignment too.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #6 of 13 Old 05-24-2009, 03:17 PM Thread Starter
76CJ5NGA
1976 CJ5
The adjustable sleeve bolts on the tie end rod were loose letting the tie end rod to rotate freely. Tightened the bolts down and now I can drive one handed without having to change my underwear!!!
76CJ5NGA is offline
post #7 of 13 Old 05-24-2009, 05:13 PM
DavidQuist
Power Steering discussion & trouble shooting
Timely topic for me. I just finished rebuilding a 1980 CJ5. It has power steering and it's also too lively...widow-maker lively. Great forum answers on where to start troubleshooting. My question: both power & non-power steering gear boxes are available (NAPA). I've had two jeeps prior without P/S and liked them a lot(lots of off-road in MT-all seasons). Does AMC Jeep P/S always have this "no feel for the road" lightness? My CJ5 is stock w/stock tire and wheel sizes. Am I old-school or should I try to get this P/S system sorted out and use it?
DavidQuist is offline
post #8 of 13 Old 05-24-2009, 06:17 PM
scottymac62
1979 CJ7
Glad you found the problem. Did you just tighten your bolts down? Or did you check your toe-in alignment before you tightened them? If not, then you probably don't have a correct alignment which will affect your steering.
post #9 of 13 Old 05-24-2009, 09:18 PM Thread Starter
76CJ5NGA
1976 CJ5
I tightened them down just to be able to get it somewhere to get an alignment done on it...I've read a lot of topics on it but still confuses me. I could rebuild a motor and a lot of other stuff but alignment stuff is like foreign language. Got any step by step instructions with pictures? LOL!
76CJ5NGA is offline
post #10 of 13 Old 05-25-2009, 05:49 AM
fuzz401
1978 CJ7
thats the way the PS is in a CJ very quick a lot quicker then a old car
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #11 of 13 Old 05-25-2009, 06:04 AM
scottymac62
1979 CJ7
Sure do!
http://www.4x4xplor.com/alignment.html
post #12 of 13 Old 05-25-2009, 07:31 AM
Happy Joe
From a totally different direction;
I have run across several jeeps with retrofitted power steering that felt like they had no linkage to the wheels (very easy to turn/would turn a corner if you sneezed wrong). These all had quick Saginaw boxes and several had pumps from Cadillacs (one of the higher pressure GM pumps).
The fixes for these were to retrofit a slower box and lower pressure pump.
Try all the other suggested fixes first (verification of caster angle is very important and most likely involved in your issue). This fix has a relatively low probability.
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
post #13 of 13 Old 05-25-2009, 08:48 AM Thread Starter
76CJ5NGA
1976 CJ5
Thanks for the link..Seems simple enough.
76CJ5NGA is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Power Steering Pulley Issue bencarlson Jeep CJ Forum 4 08-12-2009 01:24 PM
V8 Power Steering Bracket Retrofit Issue turnabout Jeep CJ Forum 1 06-07-2009 05:43 PM
Power steering issue evil-ant Jeep CJ Forum 6 10-08-2007 01:15 AM
Power Steering Parts Issue gwalls Jeep CJ Forum 4 06-15-2007 10:58 AM
