Steering issue - JeepForum.com
post #1 of 5 Old 06-12-2005, 04:02 PM Thread Starter
Fropleyqk
Fropleyqk's Avatar
Steering issue
I'm slowly sorting through my Jeep's problems and now I'm moving to steering. Currently the steering's pretty bad. Wanders all over the place. I just replaced my lower column bearing this morning. Right now, I know that the Steering Box needs to be replaced and my shackles are too big, that'll come later. But besides that, I've been reading a lot about shims and 6 degrees of castor. Being the new guy that I am, I'm not really understanding exactly how that works or where to put them. From what I've read, they can really help, I'd like to give that a shot but I'm kinda lost. Does anyone have any pics? Or a link to a good thread? Thanks everyone.
Fropleyqk is offline
post #2 of 5 Old 06-12-2005, 04:08 PM
390fastback
390fastback's Avatar
They go between the spring and the axel to rotate the axel back to its original position. To long of a shackle is a bad thing also, it will affect the drivability of you Jeep. As for pics, sorry dude, don't have any.
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
390fastback is offline
post #3 of 5 Old 06-12-2005, 05:00 PM Thread Starter
Fropleyqk
Fropleyqk's Avatar
Yeah, I know too long of a shackle is a problem and mine are. I'm eventually just going to go with a whole new lift kit, that's later though.
post #4 of 5 Old 06-12-2005, 05:39 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It's those monster shackles dude.. They're killing your caster angle. Shims might help a little but best bet would be to toss those shackles or maybe we can shorten them a couple inches on the bandsaw. If you still wanna try some shims (basically wedges that look like thin doorstops), make sure you use steel ones and not aluminum.. the aluminum ones will bend and eventually crack. I had some in the rear of my Blue CJ before I swapped axles. They were only back there for like 2 months. When I removed them, they were bent slightly to the arch of the spring and already starting to crack at the pin hole.. next, they would've spit out from between the spring and the mount.. definately something you don't want with the front axle
BESRK is offline
post #5 of 5 Old 06-12-2005, 06:27 PM Thread Starter
Fropleyqk
Fropleyqk's Avatar
Yeah, I know. I just didnt want to dive into that yet. If I shorten the shackles I lower the Jeep. If I lower the Jeep, I should buy a whole new lift kit. If I buy a new lift kit I might as well get bigger wheels. If I get bigger wheels......
Yeah, you're right though.....
Cj steering issue dadroofs Jeep CJ Forum 13 12-10-2009 10:57 AM
CJ5 Steering issue JFCIII Jeep CJ Forum 6 07-07-2009 05:56 AM
Steering issue...Power Steering seems too good!! 76CJ5NGA Jeep CJ Forum 12 05-25-2009 08:48 AM
Steering box issue onexone Jeep CJ Forum 1 02-17-2009 05:52 PM
Steering issue dali555 Jeep CJ Forum 6 04-25-2005 05:42 AM
