#1 | |
steering gear box rebuild
my gear box on my 74 cj5 with power steering is leaking and the only rebuild kits i can find are for manual steering. i need to know if these are the same gear boxes or if this one can be rebuilt. i am hoping that it might just need a seal but i can't find a parts break down for this. please help with any information.
#2 |
this might help
http://www.pirate4x4.com/forum/showthread.php?t=570869 |
#3 |
what about parts? where can i buy seals?
#4 |
They should be the standard saganaw 76 box seals. Same as the ones found on, say, a 1978 cj5. Check at your local auto parts store and compare the shaft size. You may want to pull the box and determine where you have a leak. If the box still operates well then fix the seals. Could simply be the o-rings on the hoses. Might just be the output seal........ Both are the easy to replace. Give it a good visual once-over before you tear it apart.
The two best off-road vehicles in the world -- the Jeep CJ and rental cars. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
