Steering gear box ? - JeepForum.com
post #1 of 11 Old 09-17-2011, 08:53 PM Thread Starter
nitro237
Steering gear box ?
I have a '77 CJ-5. I replaced the steering gear box and lower steering shaft. It drives great now, but still makes a squealing noise, only when I turn the wheel to the left. The belt is tight, fluid is good. Think I could have a defective gear box?
nitro237 is offline
post #2 of 11 Old 09-19-2011, 07:00 PM Thread Starter
nitro237
hmmmm, no ideas?
nitro237 is offline
post #3 of 11 Old 09-19-2011, 07:29 PM
jcalhoon84
1980 CJ5
Try belt dressing just to see if it has any effect.
jcalhoon84 is offline
post #4 of 11 Old 09-19-2011, 08:31 PM
Stumpbumper
You could have not bleed all the air out!
Jack up the front end. Take off the power steering pump cap.
Start the jeep. Turn the wheels all the way left, then all the way right.
Do this a dozen times! Does the fluid look milky. If so you still are getting air bubbles. Keep doing it!
You will probably loose some fluid! keep checking on it!
1984 CJ7, 258..HEI..MC2100, T176/D300, D30/M20 lockers, lift, warn winch!
"When in doubt! Gas it out!"
Stumpbumper is offline
post #5 of 11 Old 09-19-2011, 08:53 PM
lucdog
lucdog's Avatar
1980 CJ5
The last pump I put on, a PSC it said to not start the engine. Wheels off the ground, turn lock to lock, keep a eye on the fluid level, till no air.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #6 of 11 Old 09-19-2011, 08:57 PM Thread Starter
nitro237
I did try the belt dressing and I tightened the belt a little. It seemed to do a little better maybe , but only for a day.
The ps fluid does not look milky.
nitro237 is offline
post #7 of 11 Old 09-19-2011, 09:35 PM
lucdog
lucdog's Avatar
1980 CJ5
How old is the belt? Or the one you have could be glazed from prior slippage.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #8 of 11 Old 09-23-2011, 09:55 PM Thread Starter
nitro237
The belt does not look very old. I have only had the jeep a few weeks. A guy looked at it today, said it is the power steering pump. But wouldn't it be making the noise when you turn the wheel to the right also?
nitro237 is offline
post #9 of 11 Old 09-24-2011, 06:25 AM
lucdog
lucdog's Avatar
1980 CJ5
Since you replaced the steering box, I assume you removed the drag link from the pitman arm. It should be easy to remove again, raise both front wheels off the ground. Check for any binding, by moving the wheels back and forth.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #10 of 11 Old 09-25-2011, 06:50 AM Thread Starter
nitro237
Bill
OK, I think we may have figured out part of it. The front left leaf springs are popping when you turn the wheel back and forth. Do they make a clamp to keep the springs from popping and moving?
That doesn't explain the power steering pump whining when I turn the wheel to the left.
nitro237 is offline
post #11 of 11 Old 09-25-2011, 07:31 AM
lucdog
lucdog's Avatar
1980 CJ5
Were the front wheels off the ground when they were "popping". If they wern't, its normal for the springs to move a little, and make some noise. Did you do what I said about the pitman/drag link?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
will steering gear from 79 cj5 fit 80 cj7 cheepjeep65 Jeep CJ Forum 5 11-22-2010 05:43 PM
yj steering gear box into a cj? rickgoodnight Jeep CJ Forum 0 03-31-2009 12:53 PM
Coupler connecting steering gear to steering shaft is leaking? Natto123 Jeep CJ Forum 1 06-29-2008 12:52 PM
Trouble removing steering gear from steering shaft.... Natto123 Jeep CJ Forum 5 06-29-2008 10:56 AM
Steering gear box parsons125 Jeep CJ Forum 6 12-30-2007 08:55 PM
