Steering Column Wiring Diagram - JeepForum.com
post #1 of 14 Old 08-16-2010, 07:27 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Anyone have a 82 CJ7 wiring diagram for the steering column? I tried searching but no help. Thanks.
nedmoore is offline
post #2 of 14 Old 08-16-2010, 07:50 PM
Coiz
1979 CJ7
The column doesn't really have a diagram. Are you looking for the ignition switch portion or the turn signal switch?
Mike
Coiz is offline
post #3 of 14 Old 08-16-2010, 07:58 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
This should help:
Jeep® 1982 TSM online
Good luck!
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #4 of 14 Old 08-16-2010, 08:03 PM
82JeepCJ7
1982 CJ7
Jeep uses GM steering columns. So the wiring harness is universal with GM products.
This manual for a painless kit has all the wiring call outs.
http://www.painlesswiring.com/Manuals/30805.pdf
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 14 Old 08-16-2010, 09:02 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Thanks guys, if this doesn't help I will post a pic tomorrow...
nedmoore is offline
post #6 of 14 Old 08-17-2010, 01:50 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
I need to know what each wire is for? Does anyone have this on their steering column?
nedmoore is offline
post #7 of 14 Old 08-17-2010, 02:53 PM
Chili4me
1979 CJ7
Black horn ground
lt.blue left front turn
blue right front turn
brown hazard power
purple turn signal power
yellow left rear turn
green right rear turn
white brake light input
Chili4me is offline
post #8 of 14 Old 08-17-2010, 03:46 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Thanks Chili! Does that look like a jeep column wiring to you?
nedmoore is offline
post #9 of 14 Old 08-17-2010, 06:56 PM
82JeepCJ7
1982 CJ7
Follow that link I posted, it has all that information spelled out.
post #10 of 14 Old 08-17-2010, 07:12 PM
Chili4me
1979 CJ7
Yea- like the post above said
they used a GM column that's why it looks a little weird.
At least they look out of place to me
Chili4me is offline
post #11 of 14 Old 08-18-2010, 02:44 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Maybe these will help.
John Strenk is online now
post #12 of 14 Old 05-02-2013, 07:22 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
The painless pdf link is dead Anyone have a diagram of the ignition wiring? Trying to figure out how to start my motor without hot-wiring the starter solenoid...
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #13 of 14 Old 05-02-2013, 07:30 PM
Skerr
Looks factory to me, Ned. It will only plug in one way. What are you needing to do?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #14 of 14 Old 05-02-2013, 11:29 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Found this link here, not a wiring diagram but I did find the correct wire to turn the starter. http://autoelectricforum.com/?p=17 According to all of the wiring diagrams I've seen so far, light blue is the color from the key to the solenoid. I metered it out once I found the location of the ignition plug on the column, and it follows through the bulkhead connector to what I previously believed to be the starter wire. So that's a step in the right direction. My question now, which wire is the "run" wire? I gotta prime my fuel pump!
Andy, KD8EIA
Grewe02 is offline
77 cj5 steering column diagram rcgkaw Jeep CJ Forum 3 05-28-2010 07:00 AM
cj steering column diagram kevinrdyck32 Jeep CJ Forum 3 01-29-2010 04:06 PM
Tilt Steering Wiring Diagram RetiredSERE Jeep CJ Forum 2 12-04-2009 03:21 AM
wiring diagram needed for plug in steering column PIPER-68 Jeep CJ Forum 5 09-09-2009 09:01 PM
Wiring harness on top of steering column VACJ7 Jeep CJ Forum 3 12-02-2008 12:18 AM
