Steering Column Swap - JeepForum.com
post #1 of 14 Old 05-25-2008, 08:22 PM Thread Starter
tball
Looking to swap my standard steering column in my cj5 to a tilt column, are there any out there that are fairly simple to install with out spending a fortune for a custom one.
tball is offline
post #2 of 14 Old 05-25-2008, 08:27 PM
jcooley7
quadratec or 4wd
quadratec has one for abot 315 with tilt
jcooley7 is offline
post #3 of 14 Old 05-26-2008, 07:06 AM Thread Starter
tball
Are there any other makes or models
Are there any other makes or models that I may get at a salvage yard. I'm trying to get by cheap because I have alot of work to do on my jeep.
tball is offline
post #4 of 14 Old 05-26-2008, 10:07 AM
petey156
i have heard that cars like 70's forebirds and cameros have a similar column try s search for GM a body column. if you are up to a challenge i just put a tilit column out of a 72 AMC eagle ($20 Ebay) into my 77 cj5. only thing i had to change was i had to cut the output shart a bit and then i pinned it to my stock steering shaft.
petey156 is offline
post #5 of 14 Old 05-28-2008, 06:07 AM Thread Starter
tball
thanks for the info
I'm still looking on ebay for the one thats priced right, if anyone else has done this plese reply.
tball is offline
post #6 of 14 Old 05-28-2008, 06:52 AM
badady1
Go to www.ididit.com. They make a steering column that looks sweet and is priced right. I am about to do the same thing.
Ady's 86 Cj
badady1 is offline
post #7 of 14 Old 05-28-2008, 06:58 AM
NoNeck
http://cgi.ebay.com/ebaymotors/ws/eB...235318979&rd=1
Will sell you a restored column for $265. I spoke to him on the phone and just sent him my tilt column for a rebuild. I got my column on Ebay for $65. He said to rebuild will be between $90 and $130. He does not have any auctions listed right now but drop him an email.
NoNeck is offline
post #8 of 14 Old 05-28-2008, 01:00 PM
trctrdrvr
1971 CJ5
I'm in the process of doing the same thing, ang ideals on what length column to buy
trctrdrvr is offline
post #9 of 14 Old 05-28-2008, 05:54 PM
CJfreak
1975 CJ5
I also am doing the same thing to my '75 right now. I've heard the camaros and firebirds mentioned before too but whats wrong with staying Jeep? I'm trying to fit a tilt column from a '79 CJ into mine complete with Jeep logo steering wheel and so far the only problem I see is I may have to cut an inch out of the steering shaft and weld back together. Anybody done the same swap and what problems have you encountered?
'75 CJ5 w/304/T150/D20/D44's/3.07/33" Thornbirds/Glass Body...
CJfreak is offline
post #10 of 14 Old 05-28-2008, 06:16 PM
NoNeck
I have a steering column in my attic from a 69 Chevelle and a 72 Chevelle. If someone waht to take measurements of their CJ column, we can compare to see if a GM A-Body column will fit. (Which I believe they will.) As for keeping it all Jeep, the columns were not made by Jeep or GM I'd bet as they are all the same down to the wiring harnesses. They were probably mass produced by a second party supplier.
NoNeck is offline
post #11 of 14 Old 05-29-2008, 07:30 PM Thread Starter
tball
found one
I found one out of a 1975 camero for 100 bucks, I'm going to give it a try in a couple weeks I will let you guys know how it went.
tball is offline
post #12 of 14 Old 05-29-2008, 08:12 PM
erik5387
HA! This is the exact swap I want to do on mine...blows my mind how expensive they are! I started looking figuring I would find it for $100, boy was I wrong!! Still looking and hoping though.
1984 CJ7-restomod in progress
1966 M416 Trailer
erik5387 is offline
post #13 of 14 Old 05-30-2008, 05:47 AM Thread Starter
tball
Keep Looking
Keep looking on ebay , do a search for steering columns and you should be able to find on for a fire bird or camero fairly cheap with a buy it now option.
tball is offline
post #14 of 14 Old 06-12-2008, 08:11 PM Thread Starter
tball
completed swap
Just completed my column swap, all I had to do was to cut 1 1/4" off the old column and add to the column I got out of a 1975 camaro it was a direct bolt up.
tball is offline
79 CJ7 Steering column swap 79cj7rebuild Jeep CJ Forum 0 07-19-2009 04:37 PM
CJ steering column swap JeeperJohn Jeep CJ Forum 1 07-30-2007 07:55 AM
Steering Column Swap steveracer67 Jeep CJ Forum 1 03-23-2007 12:37 PM
Steering Column Swap voyager108 Jeep CJ Forum 3 01-13-2007 10:21 PM
Steering Column swap? 85CJ7 Jeep CJ Forum 1 06-07-2006 09:12 PM
