Steering Column rebuild - Help! - Page 2 - JeepForum.com
post #16 of 28 Old 08-29-2013, 01:53 PM
TRUVOL
You say you have a wobble. I would check the lower bearing on the lower column of the steering shaft(firewall). Mine gave me that as well. Also the coupler gave out which connects to the gearbox. Although I have PS. Hope that helps.
TRUVOL is offline
post #17 of 28 Old 08-29-2013, 03:11 PM
Skerr
You already bought the lockplate? The cancelling cam can be purchased from an auto parts store. Do you have tilt?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #18 of 28 Old 08-29-2013, 03:17 PM Thread Starter
aggiejon
1979 CJ7
Lockplate, retaining clip, and cancelling cam should be in tomorrow. I had no issues with wobble when I had the grant wheel installed. The intermediate shaft and lower coupler have been replaced. The Jeep was initially a manual steering, but has had a J20 power steering box conversion. I called the parts house and it was no cheaper than getting it online. Since they didn't have the other two parts, I just figured thats one less stop I have to make on the way home.
I hope to have it all in and installed by the end of the weekend. I'll report back on Monday as to how its doing. Thanks
aggiejon is offline
post #19 of 28 Old 08-29-2013, 05:09 PM
iluvcowjuice
1979 CJ7
You should also have a horn button between the spring and the round plate.
iluvcowjuice is offline
post #20 of 28 Old 08-31-2013, 06:24 AM Thread Starter
aggiejon
1979 CJ7
I have all of that stuff. When I bought the steering wheel, I also got a bag of extra parts, which included the horn components.
aggiejon is offline
post #21 of 28 Old 09-09-2013, 12:03 PM Thread Starter
aggiejon
1979 CJ7
An update on the steering column. Added the lock plate, retainer ring, anti theft plate and got everything tightened back down. It is no better than it was when I started. So I guess I'll drive it a little longer until I find a better column. It is just a ranch jeep so I'm not too worried about it long term. But, I'd still like it right. I guess I'll keep on at it...
aggiejon is offline
post #22 of 28 Old 09-09-2013, 12:31 PM
iluvcowjuice
1979 CJ7
Did you need to put pressure on the plate to get the snap ring on?
post #23 of 28 Old 09-09-2013, 12:31 PM
TRUVOL
Check your lower steering column bearing. In engine compartment up against firewall. Mine was bad
TRUVOL is offline
post #24 of 28 Old 09-09-2013, 12:44 PM Thread Starter
aggiejon
1979 CJ7
Cow juice, yes. It was a bear to get the ring installed. Took lots of pressure.
Truvol, can the lower bearing be replaced from under good or does the whole column have to be taken apart?
aggiejon is offline
post #25 of 28 Old 09-09-2013, 12:59 PM
TRUVOL
Yes. Its under your brake booster. You will have to disconnect your steering shaft at firewall under hood to replace it. My needle bearings were completely gone. Also check your coupler. It attaches to your gearbox. Mine was blown out. It shouldn't make any kind of clicking noise.
TRUVOL is offline
post #26 of 28 Old 09-09-2013, 01:06 PM
TRUVOL
You don't have to pull your upper steering column and not even the steering wheel.
TRUVOL is offline
post #27 of 28 Old 09-09-2013, 01:37 PM Thread Starter
aggiejon
1979 CJ7
Ok. The steering coupler is new, as I had to replace it when I swapped over to power steering. I'll try the lower bearing. See if that helps matters. Thanks
aggiejon is offline
post #28 of 28 Old 09-09-2013, 01:50 PM
TRUVOL
I bought the plastic retainer, bearing, and clip all together for 15 dollars. Make sure you pack the new bearing with grease cause my new one didn't have any and the bearing snaps into the plastic retainer. My old one wouldn't even stay in place.
TRUVOL is offline
