steering column question - JeepForum.com
post #1 of 2 Old 07-03-2002, 12:26 AM Thread Starter
camruhman
Question steering column question
Hi,
My son just spun a rod bearing in my 85 CJ-7 that I just let him start diving, so a friend is in the process if rebuilding my 400 for me.
My question has to do with my steering column
It is a tilt column and it would often work itself loose prolly due to m pulling my big butt up into the Jeep by grabbing onto it.
I had had it tightened a few times but the mechanic who last tightened it said hat there is something nside the column...maybe some sort o collar or something that has busted and the re-tightening thing will no longer work.
I need to find out if I an use a standrad GM column in a Jeep or not, as I thin I can get one fairly cheap. Or does it have to be a "JEEP" or AMC column?
Also, do I have to replace the entire column? Or can I get by with just the "upper half"....from the knuckle to the wheel itself??
Any guidance or advice will be greatly appreciated. This rebuild is going to strech the wallet and if I could grab a cheap GM volimn or part of a collumn at a bonetard it would dure help a lot.
Thanks in advance and feel free to e-mail me privately at INphotogr4@aol.com
Mark INphotogr4@aol.com
camruhman is offline
post #2 of 2 Old 07-03-2002, 07:35 PM
buddhasbomb
Talking
you can make any colum fit if ypur a good welder.the only reason to stay with a srictly cj colum is tlhe legnth would be right.perhaps a grab handle is in order?
buddhasbomb is offline
Steering column question fbnwest Jeep CJ Forum 6 06-22-2009 01:53 PM
Steering column question bigyearn Jeep CJ Forum 21 02-28-2008 09:56 AM
Steering Column question TetanusCJ7 Jeep CJ Forum 3 07-19-2007 12:33 PM
One more steering column question. Eric M.M. Jeep CJ Forum 5 07-06-2005 10:43 AM
Steering Column Question GarageCJ Jeep CJ Forum 8 12-07-2004 06:43 PM
