Steering column, and lower shaft coupling. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Steering column, and lower shaft coupling.
ZONE 4.25" combo lift for TJ available at Rockridge4wNew Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition Coi
Unread 08-23-2014, 11:46 AM   #1
donajeep
1974 CJ5
My steering started to bind when turning right. So, I started with the gear box, its leaking a little- not bad. The lower shaft coupling boot is complete garbage and in two pieces, also lots of play in the steering shaft. I will replace the whole thing with this, http://www.vintagejeepparts.com/prod...6-Jeep-CJ.html
While the shaft is out I would like to replace the lower column bearing, but cant find any info or replacement parts. Has anyone done any of this work on pre- '76 cj5? Any and all advice will be welcomed.
donajeep is offline   Reply With Quote Quick reply to this message
Unread 08-23-2014, 12:05 PM   #2
donajeep
1974 CJ5
Here's some pictures of my stock set up.
Unread 08-23-2014, 01:13 PM   #3
Spieg8
1984 CJ8
I'd contact Borgeson. See if they have a u-joint style lower coupling to replace the old bell style one that you have now.
Spieg8 is online now   Reply With Quote Quick reply to this message
Unread 08-23-2014, 07:55 PM   #4
danfrye
1978 CJ7
Hummm... looks a lot like my CJ7 Got parts here http://www.jeep4x4center.com/. Try this http://www.jeep4x4center.com/jeep-st...-scrambler.htm. Haven't had issues with jeep4x4center.
danfrye is offline   Reply With Quote Quick reply to this message
Unread 08-23-2014, 09:57 PM   #5
only in a jeep cj
The problem with the bell replacement kit is that it doesn't come with a critical piece, the pivot pin that the two blocks go on. It wears too and the best you can do is press yours out and turn it 90 degrees to expose new surfaces to the blocks.
I installed a Crown HD unit the other day and for the price, it was a huge improvement. The real u joints are smoother than the stock parts, though not replaceable if they wear out.
While it looks like it would work in a 74, The listings are 76 to 86......?
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 08-24-2014, 08:00 AM   #6
donajeep
1974 CJ5
I'm having a really hard time getting these bolts loose.
Unread 08-24-2014, 04:03 PM   #7
danfrye
1978 CJ7
Try soaking in WD40... Then Heat my friend, heat.
Unread 08-24-2014, 07:25 PM   #8
donajeep
1974 CJ5
Had to get the 16" breaker bar out.
