steering cable - JeepForum.com
post #1 of 4 Old 03-23-2010, 09:42 PM Thread Starter
sstewart252
1978 CJ5
steering cable
What kind of a price am I looking at for a steering cable, not sure if that is what its called, steering rod maybe. its connected to the steering wheel. thanks
Steve
PS. do not throw me off this site
sstewart252 is offline
post #2 of 4 Old 03-23-2010, 09:45 PM
locked-up-XJ
Im not sure what you are talking about. Are you talking about the shift cable? or the steering shaft, the one that goes from the steering column to the steering box?
1999 TJ Custom 3 Link, 2.5" FOA Coilovers, 4.88 gears, Trussed D30, Locrite lockers, 35" MTR's
85' CJ7 Project "Bentsome"
In Progress
locked-up-XJ is offline
post #3 of 4 Old 03-24-2010, 06:28 AM
JeepHammer
Running On Empty...
1973 CJ5
Steve
Welcome, and why would you get thrown off the site for asking a question?...
Your steering wheel is connected to a steering column.
That column has a shaft in the middle.
That shaft connects to another shaft in the engine bay.
Those two shafts connect to each other via a Universal Joint.
That is the 'Steering Universal'.
Between the steering column and the steering box is a shaft in a tube arrangment.
The rod will telescope into the tube to absorb a front impact if you ever get hit head on.
That piece is commonly referred to as the steering 'Shaft'.
At the end of the steering shaft, there will be another 'Universal' joint to connect it to the steering box.
It may be a 'Rag' joint, which is basically a tire side wall piece that flexes with misalignment of the two pieces (Shaft & Box),
OR,
It might be a 'Knuckle' joint, which is some metal pieces with a steel sleeve over them.
For pricing on parts, have a look at places like FWD Hardware or Quadratech or some of the other Jeep parts suppliers.
Links, Jeep® CJ Steering Replacement Parts: Jeep® Steering Column Shaft, Jeep® Column Bearing Kit, Jeep® Pitman Arm, Jeep® Power Steering Pump, Jeep® Tie Rod Assembly, Jeep® Steering Knuckle, Jeep® Ball Joint Kit. - Quadratec
CJ Replacement Steering and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
If you described the issues you are having, it would be a lot easier for us to help out diagnosing the problem...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #4 of 4 Old 03-30-2010, 06:36 AM Thread Starter
sstewart252
1978 CJ5
steering column
WOW, Thanks for the reply, yes thats what it is called Steering Column. I can't thank you all enough.
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Accelerator cable help Quentin Jeep CJ Forum 4 01-14-2008 03:23 PM
TH 400 kickdown cable? Yooper CJ7 Jeep CJ Forum 2 07-09-2007 05:37 PM
speedometer cable? duc dowg Jeep CJ Forum 2 12-23-2005 03:18 PM
Throtle cable for 360 zslnk Jeep CJ Forum 5 05-03-2005 08:07 AM
