Steering Box woes - JeepForum.com
post #1 of 6 Old 01-14-2008, 08:38 PM Thread Starter
8679cjs
Steering Box woes
I had the pleasure of having my power steering fluid piss all over my axle the other night. I refilled the pump to trace the leak and it seams that the fluid is foaming and purging thru the hole in the cap as well as leaking from the fitting on top of the steering box. I'm not looking to pour honey leak fix in there. But is this enuf damage to warrant an new steering box or just new hoses flared to fittings? Not sure and I didn't want to pull it with a snow storm on the way. Sorry no pics... Anyone ever have this issue? Advice welcomed!
8679cjs is offline
post #2 of 6 Old 01-14-2008, 08:53 PM
slacker92104
slacker92104's Avatar
I would try fixing the hose first. The foaming is probably caused by the air getting into the system from the leak.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #3 of 6 Old 01-15-2008, 06:11 PM Thread Starter
8679cjs
Thx slacker.
8679cjs is offline
post #4 of 6 Old 01-16-2008, 11:43 PM Thread Starter
8679cjs
I'm gonna drop the steering box off the frame and replace the bracket with the aftermarket beefed up version as I am running 35's. At least then I can get a wrench on the fittings to fix the leaks. Its so tight in there!
8679cjs is offline
post #5 of 6 Old 01-17-2008, 12:53 AM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
Start with the PB blaster now..Ya dont wanna beak off that captured nut in the frame..That would be a can of worms ya wanna avoid..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #6 of 6 Old 01-17-2008, 07:33 AM
Cherokeester
Cherokeester's Avatar
1980 CJ7
What he said, I spun the nuts inside the frame and had to cut an access hole and reweld them back in.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
304 Woes Scuffy Jeep CJ Forum 8 02-16-2008 03:45 AM
Oil woes 84 CJ7, 258 jayjay Jeep CJ Forum 11 01-31-2008 10:14 AM
Steering woes wildchildc1 Jeep CJ Forum 15 09-20-2006 08:23 AM
Steering Box Woes shonuff Jeep CJ Forum 5 09-15-2004 08:39 AM
lots of progess made on steering woes... NJCJ7 Jeep CJ Forum 0 06-07-2004 08:04 AM
