Steering Box Woes - JeepForum.com
post #1 of 6 Old 09-13-2004, 07:03 PM Thread Starter
shonuff
Steering Box Woes
Ok we spent the better half of the day going over the front end, some good and some bad. The good side is the prior owner replaced the ball joints, tie rods, etc... but appears to have neglected the steering box/shaft & shackle bushings. He was told to replace the parts he did and had them replaced but it still wobbled on him, one of the reasons he sold it so cheap (non-mechanical dude & it appears the local jeep shop was empting his wallet). Luckily for us the shop did a good job on the parts they replaced (according to my jeep friend) however some things still need replacing.
I am looking for advice on replacement parts:
Steering shaft assembly - Borgenson (sp?) sem to be the ones i see recommended most often.
Steering Box - autozone or ???? keeping it manual btw.
Complete Suspensin Bushing setup - Polyurethene, but which brand is prefered
I appreciate the advice, i just want to sure this thing up and do not want to waste money on oem parts that only improve the steering slightly, whereas upgrades will make it better than new.
78 (OlllllO) CJ-5
shonuff is offline
post #2 of 6 Old 09-13-2004, 07:16 PM
rcsutton
2010 JK Wrangler
If your going through all of these parts do a Power Sterring conversion. THE BEST mod you will ever do. Just finished and love it. ARG makes a good box but pricey. Really depends on what you want to do. Borgenson is a good shaft if you need it. Stock is 1/2 the price.
2010 2 door JK Red Rubicon.
rcsutton is offline
post #3 of 6 Old 09-14-2004, 09:04 AM
jeepskate
I agree with rc...if you're going to be replacing the box & shaft, this is the time to convert to power steering. You can find stock setups on Ebay, then use the box for a core if you want some piece of mind. I won't say don't use AGR, but they've had some 'issues' with quality & customer service the last couple of years (under new ownership). The original owner started up a new company, PSC, and that's where I'd go for upgraded heavy duty stuff. This is also a good time to get rid of the failure prone box mount. Flaming River or Borgeson is fine for the shaft. If you've still got the stock shackles, you might consider replacing them with some heavy duty greasable units, and you might want to replace the shackle hangers while you're at it. Yeah, the $$ adds up, but these are all failure prone items that are getting a bit long in the tooth. You can replace them while you've already got the stuff apart and do the labor once, or you can wait for them to fail on you (which could be potentially dangerous).
jeepskate is offline
post #4 of 6 Old 09-14-2004, 05:47 PM Thread Starter
shonuff
Thnx for the input, I debated the powersteering upgrade but decided to pass. The ruff steering I am used to had an old bronco doesn't really bother me & it will surely keep the wife out of the drivers seat.
I did go with a flaming river hd steering shaft, and picked up a new steering box @ j.c whitney -vs- rebuilding the existing one. I also bought a complete poly bushing set for it, and picked up greasable grade 5 bolts for the shackles. I will probablly just cut/brace my own shackles & save a few $$. After tooling with it today I decided to go ahead and replace the complete brake hose/line system and will be scouring the net for prices in a bit.
I have taken a few pictures and will post up a project progress web site this weekend, to cover all the upgrades/repairs as they go along. Just kind of a way to look back and say wow, type thing.
Anyways i xpect you guys will be seeing me around here more often now that I am expected to have this done by next winter (wife wants the master bath remodeled by end of 2005 as part of the deal to allow the $$$ to work on the jeep).
78 (OlllllO) CJ-5
shonuff is offline
post #5 of 6 Old 09-14-2004, 10:19 PM
lord_byron
lord_byron's Avatar
I'll add that you should replace the stock steering box mount. The Sam's Offroad mount is really sweet; its ALL 1/2" stock, with the nicest welds you will ever see. The Big Daddy box, and others I've seen, use 1/2" and 3/8" stock.
The Borgeson shaft is nice, but I'm not crazy about the way it mounts to the column and the box -- not nearly as secure as the stock shaft.
86 CJ7/d44, 4.27s, 33x12.5 BFG Muds, Detroits, lots more...
05 TJ X, bone stock; my daily driver
lord_byron is offline
post #6 of 6 Old 09-15-2004, 07:39 AM
83greencj7
I had the same concern about the Borgeson shaft. The Flaming River shafts use the same setup. My solution was to drill point the shaft. I also used square head set screws. I crossdrilled the heads and then saftey wired them with aircrafft saftey wire.
83 CJ-7, AMC 360, RV CAM, GM FI, AUTO WITH SHIFT KIT, FRONT DANA 44 HP LOCKRIGHT HIGH STEER, REAR CURRIE 9" HP SHAVED AND SPOOLED, 37" PJ DIRT GRIPS, AJ'S BODY FENDERS AND HOOD, WARN HS9500, OBA, BESTOP TOP AND SEATS AND STILL GOING.
83greencj7 is offline
304 Woes Scuffy Jeep CJ Forum 8 02-16-2008 02:45 AM
Oil woes 84 CJ7, 258 jayjay Jeep CJ Forum 11 01-31-2008 09:14 AM
Steering Box woes 8679cjs Jeep CJ Forum 5 01-17-2008 06:33 AM
Steering woes wildchildc1 Jeep CJ Forum 15 09-20-2006 07:23 AM
lots of progess made on steering woes... NJCJ7 Jeep CJ Forum 0 06-07-2004 07:04 AM
