Steering Box Switch - JeepForum.com
post #1 of 16 Old 04-13-2013, 09:00 AM Thread Starter
Pirate40
1977 CJ5
Steering Box Switch
I'm getting ready to pull the manual steering box to change everything over to power steering. Any recommendations or things I should & shouldn't do before I start extracting those bolts? Looking for any input here!
Pirate40 is offline
post #2 of 16 Old 04-13-2013, 09:05 AM
82JeepCJ7
1982 CJ7
Get a H1 steering box. Replace your steering shaft from the column to the box with a Borgeson (the connector needs to be changed at the box anyway, power and manual are different.)
http://www.jeepforum.com/forum/f8/th...1-box-1478332/
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 16 Old 04-13-2013, 09:47 AM Thread Starter
Pirate40
1977 CJ5
Actually have a new AGR box, Borgeson shaft & AGR pump. Just want to see if anybody has tips on the conversion.
Pirate40 is offline
post #4 of 16 Old 04-13-2013, 09:48 AM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ6
J20 box works nice as well.
Tips and tricks? Use alot of penetrating oil, hope you don't find a spinning nut in the frame when you go to dissemble. The original fasteners that attach the steering box to bracket were external torx on mine, might be on yours too. You might need some sockets for those if you don't already have. With the old box out it's a good time to check for cracks, do a good visual inspection. That's all I have, I remember it being pretty straightforward.
TIPPEDITOVER is offline
post #5 of 16 Old 04-14-2013, 09:03 AM Thread Starter
Pirate40
1977 CJ5
Looks like mine are regular hex bolts. I'm soaking them down right now with penetrating oil. I will do that for the next 2 weeks while I finish my other projects. Hopefully I don't twist one of those off.
Pirate40 is offline
post #6 of 16 Old 04-14-2013, 10:18 AM
TIPPEDITOVER
In the Lab
1978 CJ6
Another concern are the bolts in the frame. Those screw into nuts welded up inside the frame. Those welds corrode and break when you try to take out the bolts. I got lucky, I hope you do too. Go easy on em'. That's a good idea to let the oil soak in.
post #7 of 16 Old 04-14-2013, 02:00 PM Thread Starter
Pirate40
1977 CJ5
Do I dare use an impact wrench?
Pirate40 is offline
post #8 of 16 Old 04-14-2013, 08:21 PM
TIPPEDITOVER
In the Lab
1978 CJ6
I recommend no. That will most certainly snap the welds if they are close to being gone anyhow. When I did mine I used hand tools and I went slooooww. Use a cheater bar for leverage. If you get lucky and the welds don't shear then you can celebrate. If you are unlucky, then the welds shear and the nut sits and spins, or a bolt breaks off. I hope it goes well for you.
post #9 of 16 Old 04-15-2013, 08:35 PM Thread Starter
Pirate40
1977 CJ5
Thanks, Im gonna soak the Sh*t out of those bolts and hope for the best. I appreciate your input.
Pirate40 is offline
post #10 of 16 Old 04-15-2013, 09:32 PM
82JeepCJ7
1982 CJ7
Try to tighten them a little before backing them out. I have had good luck getting old bolts out by doing that. Also, an impact gun on the low setting will sometimes work better than a high torque twist from a ratchet.
post #11 of 16 Old 04-16-2013, 10:17 AM
TIPPEDITOVER
In the Lab
1978 CJ6
^^^^ Also what he said ^^^^
I forgot about tightening them a little first, helps break the bond - excellent suggestion, as usual
post #12 of 16 Old 04-16-2013, 05:29 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Take your bumper off and soak the threads from the inside.
I usually break out the gas torch and heat the beejeebers out of the bolts.
John Strenk is offline
post #13 of 16 Old 04-16-2013, 05:59 PM
skizriz
1978 CJ7
If you are religious, a prayer sure wouldn't hurt.
What they ^ said is about all you can do. Cross your fingers and hope for the best. Good luck.
skizriz is offline
post #14 of 16 Old 04-16-2013, 07:43 PM Thread Starter
Pirate40
1977 CJ5
Thanks for the input guys. I will post up when I get done.
Pirate40 is offline
post #15 of 16 Old 05-10-2014, 04:18 AM
Sherms-CJ7
1982 CJ7
Hey Pirate40,
I know this was a year ago, but how did it go? I'm going through the same thing now, but I wasn't smart enough to ask for suggestions from guys here
John
...... ___
..__,[____],
.L---L-OlllllllO-
()_)-()_)-o-)_)
... can't take credit for the graphic ... but it's cool, ain't it?
Sherms-CJ7 is offline
