Steering box leaking, losing power steering fluid - JeepForum.com
post #1 of 18 Old 11-22-2008, 03:29 PM Thread Starter
hidehunter
1979 CJ7
I'm losing power steering fluid out of my power steering pump on my 1979 CJ7. The bottom of the pump is dry, as are the hoses. It looks as if the fluid is leaking out of the box where the shaft in the box comes out to the steering wheel shaft.
Can anyone tell me if the steering box has a seal similar to the rear differential, or something similar that can be replaced? Do I have to remove the box to repair the leak, etc.
Also, the steering has a lot of play in the box. how do I adjust the box to get rid of some of that play? It has 101,000 miles. I have a repair manual, but it doesn't have any info about any of this.
Thanks,
Hide hunter
hidehunter is offline
post #2 of 18 Old 11-22-2008, 05:07 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Remove the gearbox. Either send it in, or take it somewhere and have it rebuilt. I sent mine to a place in Ohio, but there's got to be somewhere in MI that'll do it.
"In the end...It's all Hack."
HackFabrication is offline
post #3 of 18 Old 11-22-2008, 07:51 PM
dbd
1979 CJ5
Thanks,
Hide hunter
I have a 79 with the exact same problem, fluid running out the bottom of the steering shaft....
There are a couple of options, there is a seal replacement kit avail from napa which will solve the prob., or.... i was thinking I have a 30 yr old steering box so a rebuild unit was about 200 bucks so I chose the expensive choice....
I have about 2-3 inches of play in the steering wheel so was hoping to take some of that play out of the system.....
good luck
dbd is offline
post #4 of 18 Old 11-22-2008, 08:12 PM
John N
1981 CJ8
good luck
You made the right choice. Pretty much everyone I know of that tried to rebuild or replace seals in their steering boxes, ended up replacing them any way. They are difficult to get right. You could send your's off and have it rebuilt, PSC will do it, or just go a parts house and get a rebuild.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #5 of 18 Old 11-23-2008, 04:16 AM
84jeepjohn
I just had these issues too it's a Jeept hing right?Well I replaced the box and the pump (no kidding the pump started to leak 2 days after I changed the box) BUT I got mine from a auto parts chain.... it works, but I was NOT impressed with the quality of their box. Granted I've got a lifetime of new boxes when I decide to change it out. I should have just gone with PSC and gotten a new box/pump.
84 CJ-7 RE 4.5" lift TJ flares and 35"BFG's
4.88's and OX lockers front and rear
2000 Grand Cherokee, 2" lift, BFG AT's (SOLD)
2005 Z71 Suburban with 1.5" rear spacers, and front leveled
84jeepjohn is offline
post #6 of 18 Old 11-23-2008, 10:32 AM
dbd
1979 CJ5
jeep john,
should we encounter the same problem, do you have a link to the psc pump
thanks
dbd is offline
post #7 of 18 Old 11-23-2008, 11:25 AM
Hybrid Jeep
1976 CJ5
Quadratec carries them:
http://www.quadratec.com/products/56112_1000.htm
To be honest, I have been looking to find them cheaper somewhere...
Hybrid Jeep is offline
post #8 of 18 Old 11-23-2008, 01:27 PM
84jeepjohn
and right too the source http://www.offroadsteering.com/
post #9 of 18 Old 11-23-2008, 03:17 PM Thread Starter
hidehunter
1979 CJ7
Thanks for all the replies.
Is the PSC that much better than the rebuild they sell. How are they as far as steering wheel play and etc. There is a huge difference in price.
What is the difference between cylinder assist, extreme duty and variable ratio? I'd like it to be as responsive as possible. The old box has so much play its scary sometimes.
Thanks,
hidehunter
post #10 of 18 Old 11-23-2008, 03:37 PM
jscherb
Autozone has rebuilt boxes for about $185.
jscherb is offline
post #11 of 18 Old 11-23-2008, 04:53 PM
HackFabrication
1976 CJ5
^^^^ That's about what I paid to send mine in and get it rebuilt almost ten years ago....
post #12 of 18 Old 11-23-2008, 05:17 PM
John N
1981 CJ8
Thanks,
hidehunter
I like PSC and the way they stand behind their work. I sent them an AGR SB II I had about 6 years that wouldn't turn left when crawling. They rebuilt it for $100. The same problem reoccured 6 months latter. They took the $100 off another box I bought and said to send the other one back again. They replaced the first one with one of theirs, no charge...I'd only paid for a rebuild on someone elses product.
Get a varrible ratio box, unless you're mostly off road. You don't need cylinder assist until you go to 38s or bigger. You may need a new steering shaft to rid of the all of the play, they wear out too.
John N
John N is offline
post #13 of 18 Old 11-23-2008, 09:31 PM
dbd
1979 CJ5
I just replaced the box today, purchased as Riebes and it was worth the money, took about 2 inches of play out of the steering wheel, and more importantly no leakage.......
dbd is offline
post #14 of 18 Old 11-24-2008, 03:19 PM Thread Starter
hidehunter
1979 CJ7
dbd,
I checked with Auto Zone today in my area, Michigan. Their price was $189.00, after I return the the core. Special order. Lifetime guarantee.
Sounds like the way I will go. Just hope the rebuilder is a good one.
hidehunter
post #15 of 18 Old 11-24-2008, 04:29 PM
dbd
1979 CJ5
I just ran my install today and all the play and wandering that I had to get used to is GONE, the road manners are considerably changed, it actually tracks straight down the road, before i would hit the left line then the right line then the left line......
The steering is tight now and a prior post said their pump went out shortly after adding a new box, so guess I am waiting and not going out to tim-buck-two for a while till I see what happens...
but so far its good!
dbd is offline
79 cj7 power steering pump leaking bad kapooi Jeep CJ Forum 0 01-26-2010 08:08 AM
Power Steering Pump is leaking tshuelsman Jeep CJ Forum 1 02-09-2009 10:55 PM
Power steering fluid everywhere! CJeep Jeep CJ Forum 1 10-21-2007 08:38 AM
Leaking Power Steering Box.. Hibbitz Jeep CJ Forum 3 08-25-2005 10:48 AM
Power steering fluid for '83 6 cyl CJOOP7 Jeep CJ Forum 3 06-04-2003 06:44 AM
