Steering adjustment - JeepForum.com
post #1 of 65 Old 12-23-2013, 01:00 PM Thread Starter
turkish6
1982 CJ8
Steering adjustment
Hey everyone,
Is there anyway to tighten up the steering. There is like 3-4 inches in both directions that feel like the steering does nothing. Is this adjustable or is it what to expect from 82 CJ8
turkish6 is offline
post #2 of 65 Old 12-23-2013, 01:31 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by turkish6 View Post
Hey everyone,
turk,
Sloppy steering is usually due to worn steering components, or alignment problems (ie: lack of caster).
I suggest you have a look at all the components, while you have a helper turn the wheel back and forth. With that much play, the problem should be obvious.
When everything is tight and right, a CJ's steering is very quick and responsive.
Good luck,
Matt
Matt1981CJ7 is online now
post #3 of 65 Old 12-23-2013, 02:06 PM
Buckfever40
1979 CJ7
I just had the same problem. The fix for mine was a new gearbox bracket. This is the second jeep ive owned and had to replace the brackets on both of em. I your walley will allow, i recommend a heavy duty bracket. Good luck
MADE IN AMERICA.
Buckfever40 is offline
post #4 of 65 Old 12-23-2013, 02:08 PM Thread Starter
turkish6
1982 CJ8
The alignment seems to be good. At highway speeds i can let go of the steering and she continues going straight very well. I just purchased it and it's already lifted about 4 inches on 31" m/t's. There is a significant amount of oil on and around the steering box. Maybe a drop or two on the ground sometimes.
turkish6 is offline
post #5 of 65 Old 12-23-2013, 02:10 PM Thread Starter
turkish6
1982 CJ8
I will check the bracket. The wallet isnt always the issue. It's finding parts here in Turkey. We don't have 4wd.com or quadratec.com lol. When I had TJ in the states it was much easier
turkish6 is offline
post #6 of 65 Old 12-23-2013, 02:10 PM
Buckfever40
1979 CJ7
That was supposed to say "if your wallet will allow".
MADE IN AMERICA.
post #7 of 65 Old 12-23-2013, 02:13 PM
Buckfever40
1979 CJ7
I see. Thats gotta be tough owning a cj without being able to utilize 4wd hardware or quadratec
MADE IN AMERICA.
post #8 of 65 Old 12-23-2013, 02:23 PM Thread Starter
turkish6
1982 CJ8
My sister can always ship me parts but one item at a time is expensive. I need to compile a list and choose the important ones worth paying extra for shipping.
turkish6 is offline
post #9 of 65 Old 12-23-2013, 02:52 PM
skizriz
1978 CJ7
Good luck,
Matt
I don't know if I would go quite that far. Lol.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #10 of 65 Old 12-23-2013, 03:06 PM
Matt1981CJ7
1981 CJ7
Well, compared to a Porsche, maybe not. Note, I did say quick "steering" and not "handling". A CJ handles like a brick on wheels
What I really meant was, there should be very little "slop" in the wheel when everything is correct. You shouldn't have to saw the wheel back and forth to keep it between the lines. A minor move of the wheel should turn the Jeep.
Matt
post #11 of 65 Old 12-23-2013, 04:18 PM
skizriz
1978 CJ7
That sounds better. I hated to see him trying to get it to a point that is unobtainable.
I would even say that mine could be called "nimble" when in traffic.
I can Cruise all day at 60 with just a thumb on the Wheel to correct fit the crown on the roads. Took a lot of work to get to that point. When i first did the SOA not knowing any better, it was downright dangerous to Drive.
With my light weight, and higher COG, windy days still Give me problems on the highway though. Ive gotten off and on to back roads on a few occasions due to the cross winds.
skizriz is offline
post #12 of 65 Old 12-23-2013, 04:25 PM
Matt1981CJ7
1981 CJ7
Yep. I knew mine was correct when I could drape one hand over the top of the wheel, not give any thought to steering, and just enjoy the ride.
Matt
post #13 of 65 Old 12-23-2013, 04:29 PM
WSS
WSS's Avatar
1972 CJ5
Steers like a brick, flys like a brick. Good thing I did not step in it. Must be CJ's were talking about?
WSS is offline
post #14 of 65 Old 12-24-2013, 02:13 PM Thread Starter
turkish6
1982 CJ8
Only thing i see wrong is the zip tie being used. I just took a picture and didnt play around with it yet
Sorry second picture is blurry
turkish6 is offline
post #15 of 65 Old 12-24-2013, 03:13 PM
CSP
The brackets people are talking about are the brackets that hold the steering box to the frame.
CSP is offline
