Steering for 5" front stretch - JeepForum.com
post #1 of 10 Old 06-05-2011, 09:46 PM Thread Starter
garretj64
1982 CJ5
I have moved my front axle forward 5" with some custom Alcan springs, and I am having some trouble figuring out how to set up my steering. I do not want to go full hydro since I will be driving this rig on the road fairly often. I don't think the astro van box will work since i am only 5" forward. Does anybody have any ideas for me? Thanks
1982 CJ5, Corvette 383... project
garretj64 is offline
post #2 of 10 Old 06-06-2011, 07:39 AM
adamsclarke
Astro box will work, but you could also sleeve the frame with DOM and move the stock box forward and extend the steering shaft. You could also mount a scout box outside the frame and use a wagoneer pitman arm, sleeving the frame of course.
adamsclarke is offline
post #3 of 10 Old 06-06-2011, 08:31 AM Thread Starter
garretj64
1982 CJ5
So an Astro box will work with only 5" of stretch? I thought you had to go 7 or more inches?
post #4 of 10 Old 06-06-2011, 02:22 PM
adamsclarke
Run your draglink to the top and use the front hole. It will be angled back, but will work fine. Grab a shorter YJ pitman arm or one that will work if you want to tuck it back more. I used a waggy arm on my scout box since the scout arm is like 14" long vs the 7-8" for the waggy arm.
post #5 of 10 Old 06-06-2011, 02:30 PM Thread Starter
garretj64
1982 CJ5
So you are suggesting I use a astro box with a shorter pitman arm, attach the drag link to a high steer arm on the passenger nuckle and then have the tie rod in the stock location? Do you have any pics of your set up?
Thanks!
post #6 of 10 Old 06-06-2011, 07:24 PM
adamsclarke
No pics of the astro set up, but if you are running a CJ dana 30 upfront, just ream the hole in the front from the top or drill it out and weld in a tapered insert. Use the front hole for the draglink, or convert to a Y swing style steering set up that the draglink bolts to the passenger side TRE.
Here's one of my old builds that usies a scout box on a waggy 44 SUA. Every one will be different, but I'd get the astro box since it'll bolt in and figure out which pitman arm from there.
post #7 of 10 Old 06-06-2011, 09:01 PM Thread Starter
garretj64
1982 CJ5
Thanks Man I will have to pick up an astro box. I do like the scout box idea too. I am running a dana 44 with spring under as well.
post #8 of 10 Old 06-06-2011, 09:47 PM Thread Starter
garretj64
1982 CJ5
If I wanted to use a Scout box what years should I be looking for?
post #9 of 10 Old 06-07-2011, 05:00 AM
adamsclarke
That was a 1980 scout box, but any scout 2 box will work...I think it was 76+
Your power steering lines will bolt up. If I recall, it was a 30 spline borgeson ujoint I used and some 3/4" or 1" DOM to sleeve to my stock steering shaft to the column. Then just use the extra 3/4" DOM to sleeve the frame and mount the box where you want it.
post #10 of 10 Old 06-07-2011, 08:05 AM Thread Starter
garretj64
1982 CJ5
cool I might look into that. I am pretty sure the Scout box will clear my tire since I am at 65" wms wms, also I like the idea of a longer drag link. Did you have to hack up the grill or anything like that to make it work?
Time for tons, Cj5 100" stretch and tons swap No_Bs Jeep CJ Forum 53 06-23-2010 08:11 PM
Dana 60 front stretch gbrew Jeep CJ Forum 0 05-24-2010 09:34 PM
? manual to power steering on 83 "iron duke" texascj77 Jeep CJ Forum 5 07-25-2007 08:19 PM
Power Steering Hose "O-RIng" Question? Mud Machine Jeep CJ Forum 2 02-04-2006 11:39 PM
