Steering ? - JeepForum.com
post #1 of 3 Old 01-16-2002, 08:57 PM Thread Starter
tmcoors
Post Steering ?
I installed a 4.5" RE lift with the dropped pitman arm on my 79 CJ5 and I can't get the steering wheel centered. Also I can turn all the wa y one way but not the other (it stops about 1/2" from stop) Any suggestions? Is there a chance the pitman arm is off a few degrees?
tmcoors is offline
post #2 of 3 Old 01-17-2002, 03:14 AM
JIM79CJ7
JIM79CJ7's Avatar
Post
As you lifted jeep your draglink becomes shorter you can lengthen it a little by screwing out tierod ends on draglink. It wont take much , be careful to leave enough treads for collars to lock onto !
Good luck
JIM
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #3 of 3 Old 01-17-2002, 06:53 AM Thread Starter
tmcoors
Post
With the dropped pitman arm my tie rod is to long now! Is there a chance that they splined the pitman arm wrong?
tmcoors is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Coupler connecting steering gear to steering shaft is leaking? Natto123 Jeep CJ Forum 1 06-29-2008 12:52 PM
Trouble removing steering gear from steering shaft.... Natto123 Jeep CJ Forum 5 06-29-2008 10:56 AM
Size of the nut for steering column to hold steering wheel supraman1990 Jeep CJ Forum 4 02-07-2008 06:16 PM
