Stealth HEI ign, I've botched something - JeepForum.com
post #1 of 3 Old 09-03-2009, 10:15 PM Thread Starter
Olrev
1981 CJ7
Ok, trying to keep this on top as I discover things. Recently did the TeamRush, stealth hei (tested an it ran great), and grounded everything yesterday as JeepHammer detailed (did not crank or drive afterward). Today, I turned on the ignition to hear an electrical squeal (read my earlier post, i've got a video/audio clip) of constant power coming through the coil/coil wire. It would crank and run just fine, timing set at 8degrees. I took it down the road, went about 4miles, started losing power and backfired going up a hill. I geared down and over the hill the engine went dead with a loud backfire. I tried to crank it but the starter lagged bad, fighting itself...ok so I thought it was a timing issue so I left it alone. Luckily some friends with a car hauler pulled over and we took it home.
Several hours have passed and I've been racking my brain. I went down and it cranked just fine, ran for a few moments then bogged and died. I flipped my stealth box over and tested my ignition unit (not really knowing what I was doing, all I had was a test light). I cranked the engine and checked current with my test light. When I grounded the "W" post on the ignition module, the engine picked up and idled perfectly and revved flawlessly. When I "ungrounded" it, it went back to the sloppy "out of time" act. I'm gonna leave it alone tonight even though this is driving me crazy.
Why would this happen after I "dedicated-grounded" everything? Have I burned my module?
UPDATE: So it runs much better with the "W" post grounded...however, it will NOT crank with W grounded. Remove the ground, it will crank. Re-ground while running, runs better. And I didn't leave it alone tonight..
Olrev is offline
post #2 of 3 Old 09-04-2009, 06:32 AM
BigMac72
I run the stealth HEI and the only problem I had was loose contacts at the module. It would run fine and then die or not fire up. I had to crimp the connectors on to the male spades from the module. That fixed it.
BigMac72 is offline
post #3 of 3 Old 09-09-2009, 04:23 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I think you might picking up noise to the ign module causing it to miss-fire.
Noise could also be coming through the power feed causing it to miss-fire. A condenser may be needed to control the situation.
John Strenk is offline
Pre-Stealth HEI...anyone know if I can buy this part? 83cjnut Jeep CJ Forum 8 10-17-2009 12:48 PM
Stealth HEI, now no start VACJ7 Jeep CJ Forum 17 07-14-2009 03:18 PM
Stealth HEI question molsenice Jeep CJ Forum 2 05-04-2009 11:34 AM
stealth hei ? dalefan388 Jeep CJ Forum 7 02-12-2009 01:03 PM
nutter and stealth together???? martydriscoll Jeep CJ Forum 10 01-16-2009 04:59 PM
