Stealth HEI and Ford eCore upgrade - JeepForum.com
post #1 of 16 Old 11-28-2011, 10:26 AM Thread Starter
waterdowg
As the weather is starting to get colder I'm limited as to what I can get done. One of the things I want to do is Stealth HEI and Ford eCore upgrade.
I have the write-up and diagrams from JeepHammer and they seem really easy to follow
I have some questions on the what other vehicle I can get the parts from.
JeepHammer suggests:
79 Impala V8 for the ICM
89 Escort for eCore and Plug
Capacitor --- I have no ideas were to look for that. Can't find locally since I don't really know what to ask for.
What other years and models can I get these parts from?
Wanted: I'm looking for an old ICM that has good connectors. It does not have to work and can be melted, that will fit an 84 CJ. I want the case and plugs for this project. I will pay shipping.
waterdowg is offline
post #2 of 16 Old 11-28-2011, 10:40 AM
JeepHammer
Running On Empty...
1973 CJ5
Any Ford from about '86 to late 90's will have the E-core coil you are looking for,
Raise the hood, find the coil wire, follow it back to the coil,
Take the coil, connector with as much of the small wires as you can get,
There might be a 'Boot' over the coil connector, if you get that, it's a bonus,
And most of them have a 'Condenser' bolted to the coil or right near it, little rectangle looking thing.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 16 Old 11-28-2011, 11:16 AM Thread Starter
waterdowg
Thanks JeepHammer. "Condenser" I'm looking or the wrong thing.
What about the ICM what other models and years? I don't I will find any old Impalas
Also should I put heatshink ovet the Diode?
post #4 of 16 Old 11-28-2011, 11:29 AM
CSP
So you're looking for a junkard ignition module? Why? A new one can be had for $20. Just about any '76-80 Chevy V8 will have the ignition module you're looking for.
CSP is online now
post #5 of 16 Old 11-28-2011, 12:12 PM Thread Starter
waterdowg
Good point. I was just thinking if I was there, I would look for it.
post #6 of 16 Old 11-28-2011, 12:25 PM
lucdog
1980 CJ5
If you really wanted the used module. They're under the dizzy cap. On any HEI distributor. Heck, if your there and can get one for a $1, use it as a spare. I wouldn't make a special trip for one.
On the condenser, haha, went to O'reillys they didn't have a clue. Went to Car Quest told the guy I tuning up my car. I need plugs, points and condenser for a "69" Chevy. He looked it up. I told him I just need the condenser.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 16 Old 11-28-2011, 03:05 PM
JeepHammer
Running On Empty...
1973 CJ5
FORD MODULE & HOUSING/CONNECTORS
Any Ford Vehicle from '75 to about '83 should have the module housing you are looking for, you *Might* find one with good connectors in the junk yard, but I wouldn't hold my breath...
HEI MODULE FOR THE CONVERSION TO E-CORE COIL IGNITION...
You can pick up a module in about any parts store for around $20-$25, anything GM with a V-8 and HEI distributor, they are all the same.
There was only one module difference, Corvette and Police Cars, and they aren't made any more, so you get what the parts store has.
DIODE IN 'CRANKING' CIRCUIT TO HEI MODULE.
The diode DOES NOT build heat in this situation, does NOT need a heat sink, but the Ignition Module DOES need a heat sink and proper heat transfer paste. (Radio Shack or any computer supply store)
DO NOT use the clear dielectric grease supplied with the module in most cases! It's not designed to take the heat the module will produce, doesn't transfer heat well and generally is setting you up for a failure.
HEAT SHRINK.
If you intended to say 'Heat SHRINK' over the diode, then it's your call, do what you want.
I insulate the terminals with heat shrink a lot of the time, and I've encased the diode in heat shrink too with no problems.
'CONDENSER'
I wouldn't worry about a 'Condenser' unless you get ignition noise in the radio.
If you use a good set of plug wires like the recommended MSD set,
Then it's very unlikely you are going to get much noise in the radio.
Cheap wires make noise, not good ones.
If you do have noise, a condenser is available from every parts stores for a few bucks,
You can mount it at the module, or at the ignition coil, doesn't matter as long as it has access to positive side of the coil positive wire.
Is this the page you are working from?
Link: http://www.junkyardgenius.com/ignition/jeep/HEI01.html
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #8 of 16 Old 11-28-2011, 04:36 PM Thread Starter
waterdowg
Bill
I'm going to look at a family bar and figured I would walk around and look.
post #9 of 16 Old 11-28-2011, 04:42 PM Thread Starter
waterdowg
HEAT SHRINK.
'CONDENSER'
Again thanks for the info. I was asking about heat shrink. I was concerned with it hitting ground.
The condenser I figured I would put it in just incase. Figured better safe then sorry.
Yes that is the site I'm woking from.
post #10 of 16 Old 11-28-2011, 04:44 PM
lucdog
1980 CJ5
Don't forget a flat blade screwdriver to remove the cap
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #11 of 16 Old 11-29-2011, 07:57 AM Thread Starter
waterdowg
Will an Ignition Condenser from any vehicle work? Now that I knwo what to search for I find tons of then. Just different prices.
post #12 of 16 Old 12-01-2011, 06:44 AM Thread Starter
waterdowg
Anyone know?
post #13 of 16 Old 12-01-2011, 08:15 AM
CSP
Yes, if you actually need one. As said, it's job is to prevent RF noise from finding its way into your radio. With good plug wires you don't need one. You won't find many GM vehicles with HEI or Fords with Durapark II, III, or IV that use condensors.
CSP is online now
post #14 of 16 Old 12-01-2011, 08:46 AM Thread Starter
waterdowg
Thank you. I figured if I'm going to do it, I only want to do it once. So fr the 2-3 dollars I would put it in, same with the Diode.
post #15 of 16 Old 12-01-2011, 09:03 AM
lucdog
1980 CJ5
I don't know for sure. That being said,I can't imagine there would be any difference, they all do the same thing.
If you think about it, your using a Ford cap and rotor, a GM Ign module, and a Ford coil, a stock or MSD one, on a AMC engine. Personally I'd use the GM.
BILL
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
ford shock mount upgrade.....need pictures mxracer919 Jeep CJ Forum 16 05-03-2013 12:29 PM
Does the Ford Front Shock Mount Upgrade=Need Longer Shocks? jpd1899 Jeep CJ Forum 7 11-08-2010 11:28 AM
TFI FORD E COIL UPGRADE, IS CAPACITOR & GROUNDING Necessary??? Fjguercio Jeep CJ Forum 20 03-18-2009 03:51 PM
stealth hei ? dalefan388 Jeep CJ Forum 7 02-12-2009 02:03 PM
CJ Intermitent Wiper Upgrade, With FORD Part Group_er Jeep CJ Forum 8 10-02-2008 12:24 AM
