Starting Problem Help - JeepForum.com
 2Likes
  • 1 Post By TIPPEDITOVER
  • 1 Post By pedal2themetai
post #1 of 6 Old 09-22-2017, 06:26 AM Thread Starter
dastro123
1980 CJ7
My 85 CJ7 just started doing a weird thing when I try to start it. When I turn the key nothing happens accept for the volt gauge going to about 11. After a couple more turns it then fires right up. Any suggestions on what to look at?
dastro123 is offline
post #2 of 6 Old 09-22-2017, 07:31 AM
Makanak
1982 CJ7
Solenoid may be sticking.
The more I try to pursue the easy way out the more difficult it is to reach my goal.
Makanak is offline
post #3 of 6 Old 09-22-2017, 07:36 AM Thread Starter
dastro123
1980 CJ7
Should I replace it?
post #4 of 6 Old 09-22-2017, 12:03 PM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ5
Before you replace it, you can test it. Refer to pic below. Clip a ground wire from the battery negative post to the mounting flange of the solenoid and then touch the "S" terminal with a wire clipped to the positive battery post. Listen for a solid click, you should feel it click too. It's obvious if it's working right.
So make sure the solenoid has a clean ground. It gets it's ground through the mounting flange.
pedal2themetai likes this.
Shaun
1978 CJ5 to CJ6 - Build in progress......
TIPPEDITOVER is online now
post #5 of 6 Old 09-22-2017, 01:29 PM Thread Starter
dastro123
1980 CJ7
Thanks!
post #6 of 6 Old 09-22-2017, 05:45 PM
pedal2themetai
1956 CJ5
HI CAREFUL!!! when you power the S connection if it works it WELL TURN THE STARTER AND SPIN THE MOTOR UNLESS YOU DISCONECT THE + WIRE AT THE BATTERY.
Good luck
tim
TIPPEDITOVER likes this.
pedal2themetai is offline
