starting problem - JeepForum.com
post #1 of 2 Old 06-25-2002, 09:10 AM Thread Starter
higjeep
Post starting problem
I rewired a 79 CJ-5 with a 258. The only thing it will do when I turn the switch is make one loud click. The starter will not engage and turn the engine over. I need a possible solution.
higjeep is offline
post #2 of 2 Old 06-25-2002, 11:30 AM
Jeep Daddy
Jeep Daddy's Avatar
Post
I would trouble shoot the battery and starter first.
1. I would take jumper cables directly to the starter to see if it will engage. If not, check battery; try a known good battery. If battery good, pull starter and take to shop and have tested. Bad, buy new starter.
2. If that works, I'd take some power to the soloniod and see if it engages. If not, buy new solonoid.
3. If that works, start checking your ingition switch and wire back to same.
Hope this helps.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
Starting problem Chasebo Jeep CJ Forum 7 08-17-2009 03:54 PM
Starting problem... SuB8HaVeN Jeep CJ Forum 1 04-01-2007 11:30 AM
Starting Problem CJ5911 Jeep CJ Forum 8 01-05-2006 12:24 PM
Starting problem Burrlap Jeep CJ Forum 6 08-30-2004 08:29 PM
Starting Problem joconnor66 Jeep CJ Forum 0 08-11-2003 10:09 AM
