Starting Problem - JeepForum.com
post #1 of 4 Old 07-29-2010, 02:07 PM Thread Starter
Chasebo
1981 CJ5
Starting Problem
I am having trouble figuring out my starting issue. My batterie is good. All the guages turn on when i turn the key. Sometimes it will not turn over. I dont get a noise when it will not turn over. I just turn the key and the guages turn on. It cranks when im jump start it and runs good just cant cut it off ha! I think the starter is going out because some times it will turn over. Is there a way to check the starter while it is still connected. Any suggestions would be great. O yea i have a 4.3 L v-6 out of a late 70's camaro in my jeep. Thanks for the help
Chasebo is offline
post #2 of 4 Old 07-29-2010, 02:09 PM
jbanyas
It may be you solinoid and may be just the connection.
"Not all who wander are lost"
jbanyas is offline
post #3 of 4 Old 07-29-2010, 02:12 PM
walkerhoundvm
1981 CJ8
I concur - or a grounding issue.
-N
walkerhoundvm is offline
post #4 of 4 Old 07-29-2010, 02:22 PM Thread Starter
Chasebo
1981 CJ5
Besides redoing to connections is there a way to check it with a test light or anything?
Chasebo is offline
battery , battery terminal , cable , ignition , solenoid , starter
Starting problem Chasebo Jeep CJ Forum 7 08-17-2009 03:54 PM
Starting problem thantos858 Jeep CJ Forum 6 12-03-2007 11:11 PM
85 CJ Starting Problem bmg97 Jeep CJ Forum 5 05-09-2006 04:46 PM
Starting Problem CJ5911 Jeep CJ Forum 8 01-05-2006 12:24 PM
Starting Problem joconnor66 Jeep CJ Forum 0 08-11-2003 10:09 AM
