Originally Posted by texashighridin
... Right now I have the light blue wire coming from the ignition switch to the S terminal, and when the ignition is turned to run the terminal gets 12 volts but the starter does not engage.
First off,
The 'Blue' wire should ONLY be hot when the ignition switch is in the 'Crank' or 'Start' position, and should NOT BE HOT when the key is in the 'Run' position.
I've tried three different solenoids and none of them have fixed the problem.My question is does anyone have a diagram or could shed some light on the proper wiring of the solenoid?
I don't have anything connected to the I terminal and I'm wondering if there should be something there, I've read a couple of posts that say you should have 12 volts at the I terminal when the ignition is in start and run but I don't know what the source should be.
The 'I' terminal is a full voltage feed for your ignition coil when you are cranking the vehicle.
First used on breaker points ignitions, the 'I' terminal was a hold over from the old breaker points days, and found an application with the Jeep/DuraSpark module since it has separate 'Start' and 'Run' modes.
I've jumped the starter directly from the battery and the motor cranks although I haven't tried jumping from the battery post of the solenoid, so I may need new battery cables.
Jump over the solenoid/relay with a large gauge wire.
Large terminal to large terminal.
If the starter turns OK, it's the solenoid that has problems.
If the starter DOES NOT turn, it's the cables either from the battery to the solenoid/relay or to the starter.
My main question still focuses on the wiring of the solenoid and if I should have anything connected to the I terminal for power or if it should be grounded.
Jeep CJ solenoids should be grounded.
The 'S' terminal should be connected to the ignition switch 'Crank' or 'Start' circuit.
Some jeep solenoids/relays are intended to have the second terminal grounded though a clutch safety switch or neutral safety switch.
The small terminals on these will NOT be labeled 'S' & 'I'....
