Starter solenoid keep going out - JeepForum.com
post #1 of 10 Old 09-25-2007, 01:28 PM Thread Starter
colby72olds
Why would my jeep keep going through starter solenoids? I replaced it about 3 months ago, and it went out sunday. The jeep just gets trail ridden, hardly ever mud, and never deep enough water to reach the solenoid. I need yalls help please??? thanks
it's a 304c.i. BTW
95 ZJ 5.2, NP231, 2.25" BB, black steelies, 31" A/t's
80 CJ5-Sold
colby72olds is offline
post #2 of 10 Old 09-25-2007, 07:54 PM
hfjeff
hfjeff's Avatar
I had the same thing with a cheap Quadratech solenoid. It kept sticking on and finally killed my starter gear. Went to Advance and got a more expensive Borg Warner ($18) and haven't had an issue since:
http://www.partsamerica.com/ProductD...pe=575&PTSet=A
MINE: 1995 YJ/2.5L/115K/Completely Stock
MY DAD's: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass. (SOLD)
MY BROTHER's: 1996 ZJ Limited/5.2L/117K & Completely Stock.(SOLD)
hfjeff is offline
post #3 of 10 Old 09-25-2007, 08:45 PM Thread Starter
colby72olds
How do i know if it's the starter gear? Since i made this post i went to Advanced Auto and bought a starter solenoid, it didnt fix the problem. When i try to turn over the ignition, it sounds like a someone welding a bead??? Then about every other turn of the ignition, there is no sound. When there is sound my battey volts are @ 13, with no sound there are no volts. I hope this can help diagnose the problem. thanks
80 CJ5-Sold
post #4 of 10 Old 09-26-2007, 06:38 AM
jfwireless
1976 CJ7
Where are you measuring battery volts?? Using the dash voltmeter or a digital meter accross the battery terminals?
Jim
jfwireless is offline
post #5 of 10 Old 09-26-2007, 06:57 AM
Mudlite
1982 CJ7
Double check all your grounding points and the + feed wires for faults. Shorting to ground will cause the arcing sound you described. Especially crimped connectors for loose connections/ corrosion.
I was seeing this for a while too. Mine turned out to be a bad ground wire from the battery to the block. Once I replaced the wire, I havent burnt one up since. Over a year now with heavy trail riding, both mud & moisture.
82 CJ7 Laredo,258 I6, TFI,WEBER 300 RGM, Headman Headers, T5 Dana300, 2.5"suspension lift,1.5"shackle, 1"body lift, 95 YJ body, Blazer blower motor, frame up rebuild completed 5/07
The Mudlite rebuild
Mudlite is offline
post #6 of 10 Old 09-26-2007, 08:37 AM Thread Starter
colby72olds
I am hoping it is a short in a grounding wire. Last night i was rewiring some, and noticed the ground wire from battery to the block, like said above. So i will change the wire today and maybe it'll fix the problem.
What kind of wire did you all use for the ground? The wire i am talking about goes from the engine block and mounts under the motor mount?? It is only about a 10" piece of wire? I was going to get battery cable wire, but Advanced Auto didnt have any short enough.
80 CJ5-Sold
post #7 of 10 Old 09-26-2007, 02:51 PM Thread Starter
colby72olds
I was measuring the volts through the gauge.
80 CJ5-Sold
post #8 of 10 Old 09-26-2007, 04:27 PM
jfwireless
1976 CJ7
OK, I suggest you try and first measure voltage accross the battery terminals with a voltmeter as you try to start the engine, if the reading is around 12 volts then the battery is OK. If the battery terminal voltage drops way below 12 volts while cranking , you have a bad battery.
Next check the voltage with a voltmeter from the battery side of the solenoid to engine ground while trying to start the engine. The voltage here can be anywhere from 12 to 10 volts depending on the size and length of the battery cables to the solenoid and engine ground from the battery. If the voltage goes way low here chack the battery cables to the solenoid and to the engine ground. The starter gets the negative battery connection directly fron the engine ground, so a bad negative battery to engine ground cable/connection can cause a problem like yours.
If all is well next measure the voltage from the starter side of the solenoid to engine ground. You should see anywhere from 12 to 10 volts when trying to start the engine.
The starter is really around an 8 volt motor, you will see voltage drop accross the battery and ground connection while trying to start your engine becaue the starter draws lots of current, so if you are getting at least 8 volts to the starter terminal while cranking , it should work just fine.
If your starter is bad, it can draw excessive current and cause large voltage drops accross the battery cables. Sometimes a bad starter can cause these symtoms.
Your dash voltmeter gauge really only starts reading at around 10 volts, so it is not a good indicator of starter voltage while cranking.
Jim
post #9 of 10 Old 09-26-2007, 09:54 PM Thread Starter
colby72olds
thanks alot jfwireless, I will check it out tomorrow.
80 CJ5-Sold
post #10 of 10 Old 09-27-2007, 09:09 PM Thread Starter
colby72olds
I appreciate all the help guys, I found the problem and fixed it today. It was the positive battery terminal....(which was recentley replaced) but the cj fired right up and perrred like a kitten
80 CJ5-Sold
which starter solenoid should I use pajeepfreak Jeep CJ Forum 0 11-14-2009 04:50 PM
Starter Solenoid RetiredSERE Jeep CJ Forum 4 09-30-2009 11:39 AM
Starter Solenoid PODNA Jeep CJ Forum 12 03-13-2008 05:05 AM
Do ya think it is the starter solenoid? Jeep84CJ7 Jeep CJ Forum 5 11-05-2003 07:17 PM
Starter Solenoid (2) canuk01 Jeep CJ Forum 2 07-15-2003 05:41 PM
