Starter Solenoid (2) - JeepForum.com
post #1 of 3 Old 07-14-2003, 07:39 AM Thread Starter
canuk01
Question Starter Solenoid (2)
Let me ask the question a different way then previuosly to see if there is some help out there.
I replaced the starter solenoid on my 78 CJ5 304ci as it failed and kept the starter engaged. (burnt out the starter). I replaced the starter and the solenoid.
Voltage on the 'blue wire' from ignition to terminal says 12V when activated but solenoid will not 'click'. Tried the old solenoid (with starter cable disconnected) and the solenoid activated (but i know that the internals are bad) and it 'clicked'. I then applied 12V directly to the the new solenoid from baterry post and it clicked. So I think that there isn't enough power from the ignition switch to pull in the solenoid.
Does this make sense? I read somewhere that in older vehicles the wiring over time increases its resistance and could cause a voltage drop, which is not strong enough to activate a new solenoid. The work around is to install a relay (horn or other) and use the 12v from the battery through the relay to activate the solenoid.
Any suggestions?
canuk01 is offline
post #2 of 3 Old 07-15-2003, 01:44 PM
Cophgnsnuf
kill switch and push button start.... In my 82 I kept burning out the solenoid still not sure why. So anyway I took care of the problem. I ran a kill switch to the old solenoid and a push button start this bypasses the old solenoid and I now can start my jeep everytime without worry of it draining my battery. If you are interested in what it took for this send me an email and I will describe it for you
82 CJ7 36" superswampers. SOA ,2 1/2 inch lift springs and a whole lot of dreams. My baby.
Cophgnsnuf is offline
post #3 of 3 Old 07-15-2003, 06:41 PM Thread Starter
canuk01
Talking Solenoid Problem SOLVED
Believe it or not I have solved the problem with the solenoid! I changed the solenoid (twice!) which I purchased from NAPA. Something told me to try another one. This time I went to AUTOZONE and I installed it the motor jumped to life IMMEDIATELY. Amazing that the two different ones that NAPA sold me failed.
Well anyway...I am back on the road.
Lesson Learned ...Don't assume that new parts suggested by retailer will work on your application.
canuk01 is offline
which starter solenoid should I use pajeepfreak Jeep CJ Forum 0 11-14-2009 05:50 PM
Starter Solenoid RetiredSERE Jeep CJ Forum 4 09-30-2009 12:39 PM
Starter Solenoid PODNA Jeep CJ Forum 12 03-13-2008 06:05 AM
Starter solenoid keep going out colby72olds Jeep CJ Forum 9 09-27-2007 10:09 PM
Do ya think it is the starter solenoid? Jeep84CJ7 Jeep CJ Forum 5 11-05-2003 08:17 PM
