Starter not grounding? - JeepForum.com
post #1 of 19 Old 08-31-2013, 12:22 PM Thread Starter
kjcj7
1977 CJ7
The starter on my 77 cj7 recently quit working. I had it checked out and it checked out fine. I change the cable and reinstalled it and still nothing I pulled it out again set it on the fender hooked it up, and clipped one of the hood hold down to the front of it, and it worked just fine... so I cleaned everything up around the mounting bolts and reinstalled it.. Again , no luck. Has anyone ever had to run a ground wire to the starter?
kjcj7 is offline
post #2 of 19 Old 08-31-2013, 12:40 PM
Spieg8
1984 CJ8
Does the starter even click at all, or is it completely silent? When you test it on the fender, are you using the same + cable that didn't work before, or are you using a jumper off the battery? I've never needed to run a ground cable to the starter, but I've heard others have (be sure to use a heavy gauge cable if you do). You may also want to examine/clean/tighten the other ground straps to the engine to be sure they're functional.
Spieg8 is offline
post #3 of 19 Old 08-31-2013, 01:39 PM
LumpyGrits
Run the NEG(-)cable from your battery to the starter's top mounting bolt.
Make sure your eng is grounded to the frame with a ground strap.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 19 Old 08-31-2013, 01:57 PM Thread Starter
kjcj7
1977 CJ7
I have a new cable, and a new solenoid... I don't think I have a ground strap to the engine, tho... weird thing is it worked fine before.. never had this problem with a starter before. Its strange. Only in a jeep!
kjcj7 is offline
post #5 of 19 Old 08-31-2013, 02:01 PM Thread Starter
kjcj7
1977 CJ7
I have a 360 that was put in by a PO. The main ground to the battery was attached to the intake manifold, but the cable was always getting hot, so now I have it grounded to the frame. Anybody know of a good spot on a 360 to attach a ground strap?
kjcj7 is offline
post #6 of 19 Old 08-31-2013, 02:09 PM
LumpyGrits
Your main NEG(-)from the battery should go to the engine block.
Your issue could also be in the ign. switch itself.
How clean are your battery terminals?
LG
post #7 of 19 Old 08-31-2013, 02:29 PM Thread Starter
kjcj7
1977 CJ7
Everything is clean, just put in a new alternator and regulator, and cleaned up the PO's wiring mess. Solenoid clicks every time...can't seem to find a good spot to ground on the block, tho.. seems strange too
kjcj7 is offline
post #8 of 19 Old 08-31-2013, 03:50 PM
superj
Undo the bolt holding the starter on and stick the ground wire there. And you can make a ground point at the bolt boss, just behind the alternator, at the block
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 19 Old 08-31-2013, 04:30 PM
Spieg8
1984 CJ8
I think my (-) cable connects at the alternator bracket.
Spieg8 is offline
post #10 of 19 Old 08-31-2013, 05:27 PM Thread Starter
kjcj7
1977 CJ7
Cool, I think I have a bolt hole behind the alternator, now to just find the right bolt...
kjcj7 is offline
post #11 of 19 Old 08-31-2013, 07:33 PM
LumpyGrits
Mount the NEG(-) cable to the starter mounting bolt.
LG
post #12 of 19 Old 08-31-2013, 09:03 PM Thread Starter
kjcj7
1977 CJ7
Now why didn't I think of that, lol
kjcj7 is offline
post #13 of 19 Old 09-13-2013, 02:43 PM Thread Starter
kjcj7
1977 CJ7
Well after a little experimenting I finally figured it out. Ran a new ground from the engine to frame, and moved the negative ground to the battery to the front of the block. Seems to work fine again. Managed to fry a solenoid in the process.... reversed the polarity everywhere, she was trying to start with the key off, lol. Put the old one back on and it worked fine.
Ended up having to get a new battery too. Been thinking the one I had was bad, but had it tested at wall mart like 3 times and they kept telling me it was good. Finally just went ahead and bought a new one and put it in. Worked fine, right off. So don't trust wall marts battery machine! This is the second battery I've had the same trouble with there!
Anyways, thanks for all the input. Now I gotta start a new thread and try to figure out why she won't stay running!
kjcj7 is offline
post #14 of 19 Old 09-13-2013, 02:48 PM
LumpyGrits
Move the neg ground on the engine block, to one of the starter mounting bolts. Shorter 'path' for high amp flow means less loss of amps upon start up
What gauge wire did you use to gnd the engine to the frame? Should at least be the same gage as your primary battery cables.
LG
post #15 of 19 Old 09-13-2013, 03:02 PM Thread Starter
kjcj7
1977 CJ7
That was the first thing I tried. The cable got really hot... had voltage to it actually. That's when the solenoid went bad... I could light up the teat light from the neg side of the battery.... maybe just a coincidence but really strange. Moved it to the front of the block, close to the oil pump, and it started acting right....
kjcj7 is offline
