Starter help!!! ASAP - JeepForum.com
post #1 of 11 Old 10-20-2011, 02:29 PM Thread Starter
NY84CJ7
I'm stuck at school right now because my starter gave out on me I already tried the majortiy of this to get it to work but I'm hoping you guys know some little tricks thatll help me get it started I need help asap ahahha thanks guys
NY84CJ7 is offline
post #2 of 11 Old 10-20-2011, 02:35 PM
cjkcj7
1983 CJ7
Are you familiar with "popping the clutch"?
1983 Jeep CJ7 Laredo 4.2/258 I6 T5 Transmission Dana 300 Transfer case Nuttered 2.5" Skyjacker lift
Custom front/rear bumpers
cjkcj7 is offline
post #3 of 11 Old 10-20-2011, 02:36 PM Thread Starter
NY84CJ7
I have an automatic
NY84CJ7 is offline
post #4 of 11 Old 10-20-2011, 02:37 PM
troys96xj
Smack the starter with a hammer or screwdiver. Sometimes it will get it going.
troys96xj is offline
post #5 of 11 Old 10-20-2011, 02:40 PM
cjkcj7
1983 CJ7
OK. Are you sure that it's the starter? Is there any possibility that it could be the battery and/or alternator? Are all the connections clean? Have you tried to jump it? Did you try to tap the starter with a hammer?
cjkcj7 is offline
post #6 of 11 Old 10-20-2011, 02:51 PM Thread Starter
NY84CJ7
I already tapped it with a hammer. Tried jumping it. Disconnected the battery than reconnrcted it. Checked all my lines and there all good. When I flip the key over it clicks but dosent crank this happened about a week ago and I did a startter swap but I guess the ****ty autozone brand didn't work too well.
NY84CJ7 is offline
post #7 of 11 Old 10-20-2011, 02:54 PM
nhel
Solenoid problem... you can make contact by placing a screwdriver to each post of the solenoid... it will turn over and start but you need a new starter/solenoid............
nhel is offline
post #8 of 11 Old 10-20-2011, 03:03 PM Thread Starter
NY84CJ7
Ok so what exactly am I doing?
NY84CJ7 is offline
post #9 of 11 Old 10-20-2011, 03:15 PM
gosupes
Applying voltage to the "S" post on the relay will close it and send voltage to the starter. It's gonna make some sparks when touched to a pos voltage connection. Another thing you can do if you have a set of jumper is to take connect on end to the battery, blk to blk and red to red. On the other end, connect the black to the starter case and the red end to the threaded stud that goes from the relay to the starter. Sam thing, you will probably get some sparks. Be ready.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #10 of 11 Old 10-20-2011, 03:21 PM Thread Starter
NY84CJ7
Ok thanks by doing that with the cables will I fry my starter and solenoid?
NY84CJ7 is offline
post #11 of 11 Old 10-20-2011, 04:23 PM
davbytrace
1979 CJ7
Typically, clicking means not enough energy passing through the circuit.
The most common cause is a weak battery or bad connections.
But no, you will not fry the starter or solenoid when you jump across the starter relay posts with a screwdriver. It will either turn over or it won't. When you jump across the relay contacts you are imitating the ignition switch.
First of all, CHECK THE GROUNDS and battery connections. Make sure that you actually remove the ground cables, scrub/file/scrape the connections down to bare metal, then reconnect tightly.
Dave
davbytrace is offline
Starter problems - starter stays engaged KGBnumber1 Jeep CJ Forum 9 11-13-2014 12:10 PM
ignition switch or starter relay/solenoid or starter gone south? jimdubose Jeep CJ Forum 19 01-06-2014 03:35 PM
Why does starter relay click and starter won't turn over? iarepilot Jeep CJ Forum 9 02-09-2011 07:14 AM
starter making terrible noise- please help ASAP ms198 Jeep CJ Forum 20 02-05-2011 08:16 PM
Need some Starter / Starter wiring help please! SparkyCJ7 Jeep CJ Forum 14 09-09-2009 06:27 AM
