Starter continually engaged, any ideas? - JeepForum.com
post #1 of 7 Old 06-22-2013, 05:22 PM Thread Starter
Jester77
I went to crank the Yeti today and once I turned the ignition switch (with key) to the crank position, the starter would continually turn the engine. If I turned the key switch to the off position and even removed the key, the starter was still engaged. I had to disconnect one of the battery terminals to get it to stop.
Any ideas why the starter would be continuously engaged? I appreciate any feedback.
Jester
Air Force Jeep Club - Tail # 200
"You miss 100% of the shots you don't take." Wayne Gretzky
Jester77 is offline
post #2 of 7 Old 06-22-2013, 05:49 PM Thread Starter
Jester77
Further information...
If I hook a test lamp up to the negative side of the battery, and the other end to the + (positive) on the coil and turn the key switch to the run position, I get a bright light on the test lamp. If I turn the key switch to the start position, the test lamp light does not change brightness, it stays the same bright light. I believe I have the solenoid hooked up wrong some way....ugh...
Jester77 is offline
post #3 of 7 Old 06-22-2013, 06:03 PM
texasdave
texasdave's Avatar
1980 CJ7
Bad starter solenoid stuck in start position.
texasdave is online now
post #4 of 7 Old 06-22-2013, 08:29 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Yep. Happens a lot, especially if you have ever cranked it with a low/dead battery.
Rick
Cutlass327 is offline
post #5 of 7 Old 06-22-2013, 08:38 PM
bear991
1978 CJ7
Yep bad starter solenoid
bear991 is offline
post #6 of 7 Old 06-22-2013, 09:19 PM Thread Starter
Jester77
It's brand new....
Jester77 is offline
post #7 of 7 Old 06-22-2013, 10:36 PM Thread Starter
Jester77
I fixed it. I had the I and S wires on the solenoid switched. The old solenoid was mounted to the fender 180 degrees from the new one. Once I switched the blue and red wires on top of the solenoid, it purrs like a kitten!
Jester
Jester77 is offline
