Star like bolts on axles. - JeepForum.com
post #1 of 9 Old 10-22-2003, 09:17 PM Thread Starter
Later_THANKS
Later_THANKS's Avatar
Question Star like bolts on axles.
Time to replace axles.
What kind of tool do I need to lose up the star like bolts.
I tried a trox which did not work.
Please help...
Later_THANKS is offline
post #2 of 9 Old 10-23-2003, 08:26 AM
fuzz401
1978 CJ7
try a 12 pt socket on them
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 9 Old 10-23-2003, 02:21 PM
jadams68
jadams68's Avatar
Wait, the ones on the differential cover?
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #4 of 9 Old 10-23-2003, 05:59 PM
DZLCJ7
DZLCJ7's Avatar
1981 CJ7
Those bolt might also be torx bolts that need internal sockets, those tend to have a sort of star look, but i can really think of where those might be on the axle, the only place ive seen them on a jeep is on the steering box mounts. Just my .02
1981 CJ7 w/ IH Dana 44s f/r, 3.07 gears, NV4500, 3.9L 4BT CTD, Dana 300, 31" Procomp MTs, 3" of lift, soon to get D60/14Bolt & 37s
1991 YJ
DZLCJ7 is offline
post #5 of 9 Old 10-23-2003, 08:16 PM Thread Starter
Later_THANKS
Thanks !!!!!
I will try the 12 pt.
Now the questions is where to get them ?
Rob99 Fan Club Member#00
Beware users with very thin skin:
gschretter
post #6 of 9 Old 10-23-2003, 09:14 PM
Jwhit
Jwhit's Avatar
I think you need to be a little more descriptive in what you ask. Assuming its a CJ5 or 7 and you are refering to the torx bolts on the differential cover.. I just did mine and it took a torch and a nice new sung torx bit. I heated up the metal around the bolts and sprayed them with some penatrating oil. waited a couple mins so the metal cooled a bit and torxed them off. Good luck
'85 CJ7 Rebuilt 258/T5/Dana 300 Mopar MPI fuel Injuection kit - 35" Pro Comp X-Terrains,one piece rear axle, 4.56 gears, Tracloc rear, Detroit Nospin front, 2" Full-Traction Shackle Reversal, 1" body lift, 2.5" Sky Jacker lift
'05 Jeep "Willys" ~stock... daily driver
Jwhit is offline
post #7 of 9 Old 10-24-2003, 10:30 PM
CSP
I was thinking the same thing as Jwhit. The description is definitely lacking.
The diff cover bolts are definitely Torx.
CSP is offline
post #8 of 9 Old 10-25-2003, 02:11 AM
jeffs77CJ5
jeffs77CJ5's Avatar
Yes more information would help
The diff cover bolts on mine are 7/16 bolts. Just goes to show you people will make do with what they have. I have for years haha
that is on my 77 CJ-5 anyway
jeffs77CJ5 is offline
post #9 of 9 Old 10-25-2003, 11:46 PM Thread Starter
Later_THANKS
12 pt did it.
Thanks so much.. !!!!!
gschretter
1" Day-star BL ? Rollbar Jeep CJ Forum 10 02-01-2009 12:16 PM
4 star engine reman??? dirt4900 Jeep CJ Forum 1 01-02-2009 09:38 PM
Removing those blasted star screws crawdad Jeep CJ Forum 11 05-08-2008 05:49 AM
Jeep wont star on a incline TATTER67 Jeep CJ Forum 9 02-28-2008 10:09 AM
help! super star cj-7 anybody seen one? CJSELLER1 Jeep CJ Forum 9 11-18-2005 09:53 AM
