Stacking coolers - oil, power steering, trans - JeepForum.com
post #1 of 11 Old 05-13-2013, 10:56 AM Thread Starter
offroadz
1980 CJ7
I'd like to add the OIL and PS cooler to my setup but would would all 3 of the coolers hinder my radiator somewhat here in the desert heat?
Right now just the trans cooler is mounted in-front of the radiator(would like to add PS & oil).
Are there other locations to mount these coolers to do the job?
offroadz is offline
post #2 of 11 Old 05-13-2013, 11:16 AM
Davis77Cj
1977 CJ7
there is a plenty of locations to mount them. The location is determined by the load you are putting the cooler under and the physical size of it. some pics would be helpful
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #3 of 11 Old 05-13-2013, 11:21 AM
wm69
Tag. I want to add an Automatic tranny cooler to my A/C equipped Jeep. Condenser is already in front of the rad, so not sure what to put where.
wm69 is offline
post #4 of 11 Old 05-13-2013, 11:27 AM Thread Starter
offroadz
1980 CJ7
Not much to show at this point. Just a trans cooler in-front of the radiator. Just curious if mounting in different areas will be effective or at least worth it to do if not in-front of the rad.
Thanks and pic attached that I had handy.
offroadz is offline
post #5 of 11 Old 05-13-2013, 12:11 PM
Davis77Cj
1977 CJ7
If it were me i would do my best to find another location for the oil cooler to keep the chance of overheating down. The small size of the PS cooler shouldnt make that big of a difference in front of the radiator. If you wanted to you can modify the top of the shroud to fit the cooler there. with the oil cooler you could mount it on the bumper in front of the grill or on the fender in the engine compartment using the small finned cooler. Or you could go with a cooler that has a fan attached to it and mount it under the body on the driver's side below the seat.
post #6 of 11 Old 05-13-2013, 12:41 PM Thread Starter
offroadz
1980 CJ7
Thanks for the pics and suggestions.
Would there be an issue with mounting the OIL cooler under the passenger side seat? Since the oil filter is along the same-side, wasn't sure if there was a particular reason that it should be mounted under the drivers seat as you suggested.
Thanks!
offroadz is offline
post #7 of 11 Old 05-13-2013, 12:57 PM
AFRd_CJ5
1976 CJ5
You can also look into dual circuit coolers like Derale has.
http://www.summitracing.com/parts/der-15321/overview/
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #8 of 11 Old 05-13-2013, 01:00 PM
Davis77Cj
1977 CJ7
I wouldnt suppose so because I am not sure why I put the drivers side.
post #9 of 11 Old 05-13-2013, 01:03 PM Thread Starter
offroadz
1980 CJ7
Since I'm not mechanically inclined, I have to make sure I question everything.
offroadz is offline
post #10 of 11 Old 05-13-2013, 01:05 PM Thread Starter
offroadz
1980 CJ7
That looks perfect for the Power Steering. Price is nice also!
offroadz is offline
post #11 of 11 Old 05-13-2013, 01:06 PM
Davis77Cj
1977 CJ7
glad you did! haha the only concern with it being on that side is keeping the lines up and out of the way of the t-case, drive shaft and the trans. heat/rubbing with cooler lines= bad day of wheeling and sore feet
