Stabile and Winter Driving? - JeepForum.com
post #1 of 6 Old 01-12-2010, 06:48 PM Thread Starter
JDurkin1234
304 recently rebuilt and my friend swears by adding stabile to the fuel for the winter. I run 93 octane (seems to run smoother) and try to get it out for a short (3-5 mile) drive once a week. It is garage kept and temps this time of year are from the single digits to freezing.
I think it is started and driven enough to go stabile-free.
What are your thoughts?
Chief Officer of the Department of Redundancy Department
JDurkin1234 is offline
post #2 of 6 Old 01-12-2010, 07:47 PM
ccbhunter14
I don't use any in mine and I usually run 87 octane, i think you'd be fine going stabile-free
If it's not leakin', it's probably empty '84/'77 CJ7 Ford 302 4bbl Holley
Just Enough Essential Parts
I drive like everyone's out to get me...because they are!
ccbhunter14 is offline
post #3 of 6 Old 01-13-2010, 01:56 AM
jeepmaster03
1982 CJ7
For the usage and storage you have described for your Jeep I would say no stabil is necessary. Stabil keeps gasoline "fresh" for up to 1 year in storage. But I have also heard that it can gum up a carburetor or fuel injection system. It has been suggested that sea-foam is a better additive to keep gas fresh in storage.
jeepmaster03 is offline
post #4 of 6 Old 01-13-2010, 03:02 AM
Ziptie2k2
I've stored my 86 every winter for 5 years now and never used any additive. I start it, drive it up and down the block, and park it once a month. However, it seems that every small engine I've had starts to run bad after a couple years without it. Now I use it in every lawn mower, motorcycle, etc.
1977 - CJ7.......1979 CJ7.......1981 - CJ8.......1986 CJ7 Cant get enough!
Originally Posted by 442Wrangler View Post
where do you believe you go when you die?
Originally Posted by sanchagrins View Post
you go in the ground, duh.....
Ziptie2k2 is offline
post #5 of 6 Old 01-13-2010, 06:19 AM
Mike Romain
On a garage kept vehicle, I like to use some gas line antifreeze to help absorb any extra condensation that occurs. Keeping the tank full also helps keep the condensation down.
Though I don't see gas line antifreeze on the shelves much any more. This is likely because they put enough alcohol (ethanol) in the gas to absorb huge amounts of water.
Mike
Mike Romain is offline
post #6 of 6 Old 01-13-2010, 06:20 AM
Bow-hunt-er
1978 CJ7
Same here, garen tractor, snow blower, snow mobile, atv's...
1978 CJ7, AMC360, D30 front, D44 rear, lock-rite lockers front & rear, 3.73 gears, Dana 20 transfer, T-18 4speed tranny
Bow-hunt-er is offline
winter cj project kgruszka Jeep CJ Forum 1 11-10-2009 10:16 PM
Herc'ing in the winter sgtbookie Jeep CJ Forum 12 02-16-2008 07:37 PM
winter driving with no top. 48 willys Jeep CJ Forum 14 11-22-2007 12:09 PM
Winter Driving & CJs jborkowski Jeep CJ Forum 9 02-16-2007 03:36 AM
Winter woes!!!!!! dali555 Jeep CJ Forum 7 12-23-2004 05:01 AM
