Sr4 transmission main shaft removal - JeepForum.com
post #1 of 3 Old 11-01-2013, 08:03 PM Thread Starter
Emory
Before I start I know the sr4 is a turd but that's what I have. I am trying to remove the main shaft, I have removed the shaft for the counter shaft,reverse idler and shifter removed,the input shaft and removed the 3/4 synchro, now I am trying to remove the 3rd gear I can slide it froward but I can't get it out, the main shaft won't move up enough to get it out, I am stuck now, help
Emory is offline
post #2 of 3 Old 11-01-2013, 08:41 PM
only in a jeep cj
If its like other transmissions Ive worked on, You may need to drive out the rear bearing to allow room for the tilt of the main shaft to slide back, tilt up and clear to come out.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 3 Old 11-02-2013, 07:04 AM
keith460
Jeep. There's Only One
keith460's Avatar
The T4/5 transmissions are the same way, knock the back output shaft out so you can move the main shaft back a bit to tilt up and out. Just remember to have the shaft in the case BEFORE putting the output shaft back in when assembling.
1984 CJ-7 Renegade
keith460 is offline
