squirrly rear end - JeepForum.com
post #1 of 5 Old 08-15-2009, 08:38 AM Thread Starter
redneckXJ
1978 CJ5
squirrly rear end
I have a 78 CJ-5 golden eagle. I just got it last week with the 304 and a 6" lift on it. The issue that I am having is if I back off the throttle and then jump back on it, it feels like the rear end is twisting sideways. I thought that It might have a lockrite in it as mine used to do this in my XJ just not as bad.
redneckXJ is offline
post #2 of 5 Old 08-15-2009, 08:48 AM
LSUtiger
1980 CJ5
With 6 inches of lift, do you have soa? Maybe you need a traction bar.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #3 of 5 Old 08-15-2009, 08:48 AM
1984CJ
1984CJ's Avatar
sounds like a Lunchbox type locker. My 84 started doing this after I put one in.
If you get off the throttle it does it- if you get back on it it does it. Much more noticeable at higher speeds.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #4 of 5 Old 08-15-2009, 08:59 AM Thread Starter
redneckXJ
1978 CJ5
I was thinking about the traction bar just trying to find one. And that is exactly what it does very noticable at high speeds.
post #5 of 5 Old 08-15-2009, 09:16 AM
JeepHammer
Running On Empty...
1973 CJ5
Lift loads on different sides during acceleration/deceleration.
Probably an open diff since the movement is dramatic.
Remember, engine torque unloads the right rear when you accelerate, and plants the right rear when you decelerate.
(One wheel wonder peel in open diff vehicle with enough power to spin one wheel)
Soggy urithane bushings will cause the diff/springs to move around quite a bit under the vehicle magnifying the 'Issue'.
The extra length in the lift springs will allow the springs to flex more as you Load/Unload the rear end...
And if your frame bushings are shot, or been changed over to soggy urithane, that will further magnify the problem.
NOW!
IF you street drive the vehicle, and you want to stop a bunch of this crap...
Knock out the urithane bushings that allow for large deflection angles,
And press in some stock, hard rubber bushings in frame and springs.
Get rid of 'Lift Shackles'! Those kill your steering geometry and magnify deflection.
Go back with stock height shackles, and weld in supports between the side pieces to keep them from further deflecting. You are looking for 'll' shackles, not '//' or '\\' shackles.
Using a soft but resilient engine and transmission mount will take much of the engine torque issue out of the situation,
And DO NOT forget the torque arm on the transmission/transfer case mount!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
Rear end-Left Rear tire noise? 84jeepcj7 Jeep CJ Forum 8 02-20-2011 10:49 AM
Holes in rear corners w/ GPF rear bumper Coiz Jeep CJ Forum 1 08-29-2009 03:22 PM
Rear end on jacks, can't turn rear axles by hand DT5150 Jeep CJ Forum 10 03-20-2009 07:17 AM
stock rear bumper? Tow points in the rear... jlr69s Jeep CJ Forum 17 05-15-2008 07:23 AM
Rear Diff Angle/Rear driveshaft w/pic DuggerCJ Jeep CJ Forum 12 12-17-2007 05:43 AM
