Squeeling noise - JeepForum.com
post #1 of 9 Old 10-02-2013, 05:52 PM Thread Starter
HMS
Squeeling noise
Upon starting my stock 83 CJ, 4.2, 4 speed I sometimes get a squealing noise that sounds like slipping belts. I have installed new belts and a new power steering pump and thought I solved the problem. But all of a sudden it did it again. Could the squealing be from a throw out bearing? When it happens I notice that if I let out the clutch, in gear, it stops. I have let the clutch out in
neutral and it still squeals. Any ideas?
Howard
HMS is offline
post #2 of 9 Old 10-02-2013, 06:00 PM
Frankandsteph
1979 CJ7
Could the belts be to tight?
Frankandsteph is offline
post #3 of 9 Old 10-02-2013, 06:14 PM
wellmax
my old 1984 did that for awhile, it was the throw out bearing,
not much way to lube it at this time without teardown.
mine: I just kept driving it and the noise when away, no noise in last 2+ years.
hope you have such luck,
wellmax is offline
post #4 of 9 Old 10-02-2013, 06:56 PM
LumpyGrits
Tight'n the belts, just a bit.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 9 Old 10-03-2013, 06:45 PM Thread Starter
HMS
I guess I'll just wait it out. The bad part is that it only happens when your around people in a parking lot.
HMS is offline
post #6 of 9 Old 10-03-2013, 06:56 PM
CJ7KAHUNA
LG
This - my 85 did this about a week after I installed new belts. I re-tightened the alternator belt just a bit and the squeal stopped. Its been about a month and so far so good.
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #7 of 9 Old 10-03-2013, 08:58 PM
Spieg8
1984 CJ8
If you have V-belt(s), it could be glazing on the pulleys. Try using some steel wool on the pulleys where the belt contacts. You can also try some belt dressing (don't really like using it myself, but if all else fails...).
Spieg8 is online now
post #8 of 9 Old 10-04-2013, 06:35 AM
gmakra
It sounds like you may have polished sheaves (pulleys) if you look at the sheaves are they very shinny? Belt dressing will help for a short while but once the stuff dries you will be in the same boat.
One thing you could do is take the sheaves off at the crank, water pump and power steering pump and have them bead blasted that will break the glaze and the problem should go away.
gmakra is offline
post #9 of 9 Old 10-04-2013, 06:59 AM Thread Starter
HMS
Never thought about the slick pulleys. I'll try some steel wool and see what happens. Pulling them off doesn't sound like much fun.
HMS is offline
