Squeeky clutch pedal - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Squeeky clutch pedal
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitBrand New! Quadratec LED Headlights!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 05-11-2014, 08:43 PM   #1
hicks1983
Anyone have any good suggestions for something to do to/put on my super squeeky clutch pedal? It's loud and annoying. Some kind of grease? Thanks
hicks1983 is offline   Reply With Quote
Unread 05-11-2014, 09:12 PM   #2
80cj
80cj's Avatar
1980 CJ5
I apply grease to all the pivot points. Quiets things down and smoothens out the clutch pedal action.
80cj is offline   Reply With Quote
Unread 05-11-2014, 11:23 PM   #3
ChrisCarlock
1982 CJ7
I'm glad you brought this up, I have been suffering from this problem for freakin ever. I have used white lithium grease and no dice. I still have a squeaky clutch
ChrisCarlock is offline   Reply With Quote
Unread 05-12-2014, 03:51 AM   #4
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The bell crank has a grease nipple on it for the ball joint pivots. Have you greased it?
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 05-12-2014, 01:05 PM   #5
hicks1983
Haven't greased it yet because I need to get some grease. I assume pb blaster wouldn't be very effective?
Unread 05-12-2014, 01:10 PM   #6
Mike Romain
First time I greased mine it took about 1/3 tube! It was dry.
Mike
Unread 05-12-2014, 01:54 PM   #7
hicks1983
Any chance you have a photo of this bell crank grease nipple? Not sure where it is or what it looks like
Unread 05-12-2014, 07:05 PM   #8
Mike Romain
The bell crank goes between the body and the engine. It has a ball and socket joint on each end and a grease gun nipple about half way across it on the bottom side.
Mike
Unread 05-13-2014, 01:41 AM   #9
keith460
Jeep. There's Only One
keith460's Avatar
These bellcrank fittings need to be greased as well as the tube itself needs to be filled with grease.
Plus, squeaks may be coming from the pedal return spring area and you might try stuffing the spring with a piece of foam or wiping it down with grease also.
I used rod ends and real bronze bushing on every pivoting part of the clutch assembly when I had it apart for replacement. You can do either or and make squeak noises disappear forever and wearing out the parts will be far and few between with these simple upgrades.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
