Squeaking when changing gears - JeepForum.com
 2Likes
  • 1 Post By LumpyGrits
post #1 of 12 Old 09-19-2017, 09:52 AM Thread Starter
Bluefire35
Hello I have a 1977 cj5 that had started to squeak alot whenever I shift from first to second it dies down after I shift in 3 but when ever I'm in first it starts squeaking
Sent from my HTC One M9 using Tapatalk
Bluefire35 is offline
post #2 of 12 Old 09-19-2017, 11:42 AM
Megaram
Throw out bearing?
Megaram is offline
post #3 of 12 Old 09-19-2017, 02:38 PM
LumpyGrits
Cj
Engine or tranny mounts.
Exhaust system rub'n somedangthing.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 12 Old 09-19-2017, 03:32 PM Thread Starter
Bluefire35
I could hear it coming from the transmission and it's mostly when I have it in first gear 2 and 3rd it goes away the gear box does have a lil play so could that be it ?
post #5 of 12 Old 09-20-2017, 02:55 PM
LumpyGrits
Cj
When was the last time the tranny and t'case oil level was ck'd?
LG
Bluefire35 likes this.
post #6 of 12 Old 09-20-2017, 03:14 PM Thread Starter
Bluefire35
LG
Hasn't got check I am going to take it this weekend which was what i thought it might be low it's has only 54 k miles on it so it's never been drained
post #7 of 12 Old 09-20-2017, 03:14 PM Thread Starter
Bluefire35
Thanks
post #8 of 12 Old 09-20-2017, 04:27 PM
LumpyGrits
Cj
ALL fluids should be ck'd, at every engine oil change!
At 54K miles it should have been changed a couple of times already.
Learn to do it yourownself---
LG
post #9 of 12 Old 09-20-2017, 06:12 PM
80cj
80cj's Avatar
1980 CJ5
Dried U joint can make a squeaking sound but are not related to gears, more to vehicle speed.
80cj is online now
post #10 of 12 Old 09-21-2017, 09:12 AM Thread Starter
Bluefire35
LG
Yea I hear you I just got it about 4 months ago so I'm not sure as to when they changed it if I could do something myself I'll do it but not really too familiar with jeeps also the skid plate seems to be in the way but I'll check it out thanks
post #11 of 12 Old 09-21-2017, 09:14 AM Thread Starter
Bluefire35
As you could see from when I got it to how it is now it's been a project
post #12 of 12 Old 09-21-2017, 09:24 AM
LumpyGrits
Cj
Check'n fluid levels is easy. All you need is a couple of wrenches.
All fluid levels should have been ck'd the day you drove it home.
LG
