Sputtering, Coughing, Loss of Power - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Sputtering, Coughing, Loss of Power
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinNEW KOR LED Lights from KrawlOff-Road.comWIN a Mammoth Lift Kit for your Wrangler at ExtremeTerrain
Unread 03-23-2014, 01:02 PM   #1
AtlantaCJ7
1980 CJ7
1980 cj7
I went thru a puddle last year, it wouldn't start after got it home. I went thru the plugs, distributor, and finally the air filter. It turns out I sucked up some dirty water thruthe intake and into the carb. I changed the air filter dried out the filter pan and it cranked right up. Since then it has a loss of power and it's spittering and coughing until it warms up...like 30 min of driving to get it really warm. Any thoughts on what is making it sputter? I tried to spray carb cleaner in the carb, about 15 small sprays, hoping to clear the jets. My next thought is to replace the fuel filter. Any other help? I have a carb rebuild kit but wanted to check u guys first. Thanks
AtlantaCJ7 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2014, 01:18 PM   #2
moto450r
Which carb do you have?
BORN 196# - DIED 20##
Currently living thru the DASH in the middle
moto450r is offline   Reply With Quote Quick reply to this message
Unread 03-23-2014, 01:19 PM   #3
crouse11c
What carb do you have. I would make sure you choke is working right. You my have hurt it a ill with that water. You can remove the filter off and cup the intake with your hand not allowing as much air in. Does this help it run better?
Change fuel filter just because!!!
Check all vacuum lines and PVC valve.
I would find out why temp is not getting warm. No or bad thermostat stuck open.
I would pull carb and look for any rust at all. Clean up the carb good. If you find any rust rebuild or replace.
That is where I would start if all these check out we move on. Also how does it idle when does it like to mess up.
crouse11c is offline   Reply With Quote Quick reply to this message
Unread 03-23-2014, 08:23 PM   #4
AtlantaCJ7
1980 CJ7
I'll cup the carb, I haven't tried that. It's the standard carb. I replaced the fuel filter, it didn't fix it, which i didn't think it would but can't hurt.
I drove it for 10 min sputtering at low speeds, everytime losing power. It definitely feels like like an air/fuel thing.
I don't know how to check the choke or the vaccum lines...
I can take the carb off, no problem, how would u suggest to clean the carb? Completely rebuild or clean it w carb cleaner? Soak it or other?
Unread 03-23-2014, 09:00 PM   #5
crouse11c
Cupping the intake when running will acts as a choke limiting the air that is getting in. It will also run better if there is a slight fuel issue. It doesn't always help. But if it makes a differance then I point at fuel or carb.
Unread 03-24-2014, 07:11 AM   #6
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
With that much water around, I would first check out the distributor cap inside looking for carbon tracks. Second I would check the gas tank vent by driving with the gas cap cracked open. The vent canister has an air filter on the bottom.
If those don't show anything, I think I would next do a compression check. Water can damage pistons. If a sparkplug got steam blasted, it will look way cleaner than the rest.
Last I would be looking to the carb.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 11:52 AM   #7
86cj74.2L
86cj74.2L's Avatar
If all else fails I'd look at the ICM and coil.
Is there goo tracks running down from where the ICM mounts?
86cj74.2L is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 03:50 PM   #8
AtlantaCJ7
1980 CJ7
you think i have a compression problem? THat would suck. I looked at the spark plugs when it first happened and wouldnt crank, and they didnt look like they got steam blasted. Hopefully thats not it. i have been figuring its a fuel/air issue, ie a carb issue. granted i'm not the most knoweldgable, but whats the easiest way to rule 1 or the other out? Is there a way to really clean the carb out without having to totall rebuild it?
I drove it last night, and it starts up fine, although it takes 2 times each time to start it up. It sputtered intermittently until what i feel was when it was warm, which was 5-10 min, and it was noticably better...then i went to the store, and it drove almost 90% perfect after that...i didnt go up any big hills, but i felt like it had a good bit of power...i am wondering if this has to do with the engine warming up?
thnaks
Unread 03-24-2014, 04:10 PM   #9
LumpyGrits
Check for damaged/bent p'rods. Sounds like you had a hydro. lock to some extent in the engine.
Do a compression ck.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 06:37 PM   #10
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
LG
This^^^^
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 03-29-2014, 09:27 AM   #11
AtlantaCJ7
1980 CJ7
Appreciate everyone's insight....some problems have simple solutions. I googled cleaning the carb, and took the Venturi out, spray the heck out of that w carb cleaner and she runs like a dream. Thanks for the help. I highly recommend that solution on anyone that has an idle issue, it seems to be a very common thing w the carter bbd. That's saves a ton of cash.
Unread 03-29-2014, 11:16 AM   #12
Mike Romain
Lots of us also drill out the crimped end on the venturi tubes to 32 thou. This really helps let any dirt pass through. I use a set of welding torch tip files for this, but they do sell mini drill bits that size.
Mike
Unread 03-29-2014, 01:41 PM   #13
86cj74.2L
86cj74.2L's Avatar
There are a lot of different idle tube drilling size threads. Most of them asking the question.
I settled for .037 on the ones I drill out.
