Spring... time to swap thermostats? - JeepForum.com
post #1 of 3 Old 03-24-2003, 08:03 PM Thread Starter
cinnamonbelle
I have a CJ7 6 cyl. that has aftermarket air (in fact very durable, amazingly durable aftermarket air)... but there's been a longstanding issue I'd appreciate any suggestions on.
The air puts a strain on the vehicle which has always been relatively temperature-sensitive (gets hot easily) anyway. What's a good temperature thermostat to be using, assuming one's not driving in the arctic, not even the midwest, and will be using the aftermarket air?
Are there any other things that would be helpful to do (or problems to look into) regarding the gets-too-hot-too-easily issue?
Thanks,
CB
cinnamonbelle is offline
post #2 of 3 Old 03-25-2003, 07:35 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Your engine was designed to use one temp thermostat and NONE OTHER. Some guys use lower, but this is basically a high performance mod (sometimes), and has a real downside. If it's a late model, it's like 195* - keep it.
But you can 1) use a "better" t-stat, like a Robertshaw, 2) get a biggger radiator, 3) a better water pump (like a Flowcooler), 4) get an auxiliary oill cooler, or any combination of the above. In truth, the most effective is a bigger/better radiator.
Lowering the temp on the t-state will not keep you from running hot, it just means the system will "turn on" sooner, but once your running warm, the higher t-stat would be full open anyway.
Sorry if this sounds like a rant, but it bothers me that some people (not you) tell others to swap the t-stat when they don't understand what it really does.
OR - just don't use the A/C
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 3 Old 03-26-2003, 07:54 AM Thread Starter
cinnamonbelle
Thanks - the Jeep has been sidelines for awhile and I'm now about to get the transmission replaced and put it into more regular use... it's had occasional maintenance, but one of the risks of not using a Jeep all the time is forgetting what work's actually been done on it in the past.
I recall getting a larger radiator some time ago and will check w/my mechanic about the current temp of the thermostat. I appreciate the other suggestions - hope to not have to resort to them, but saved your message to my hard drive for the in-case option.
yj spring swap ? oteps Jeep CJ Forum 10 01-23-2009 09:52 PM
Help with yj spring swap dcain Jeep CJ Forum 5 02-28-2008 05:46 PM
YJ spring swap.. drespecki Jeep CJ Forum 3 08-17-2007 08:55 AM
thermostats BlueFalcon Jeep CJ Forum 16 06-03-2007 01:06 AM
Spring swap 72 CJ Jeep CJ Forum 1 08-03-2002 02:03 AM
