Spring swap with full widths? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Spring swap with full widths?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe ULTIMATE "Selectable" Locker System! BroughFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 07-07-2013, 10:03 AM   #1
Alex77cj7
1977 CJ7
I'm already soa with my factory springs but I'm about to put some 3/4 - 1 ton axles under it and I am wondering if it is necessary to swap leaf springs in the front or rear? What leaf spring swap is the best? Which is easiest? Which is cheapest?
Vie been searching for a while and can't seem to find any info on this.
Any help at all is greatly appreciated
Thanks,
Alex
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
Alex77cj7 is offline   Reply With Quote
Unread 07-07-2013, 11:36 AM   #2
jeep_boy02
1980 CJ7
will most likely have to go "fullwidth" mounts in front... rear is optional... leave the springs in mounts under the frame for more articulation and less fab work or outboard them for more stability. as for springs I'd say going with YJ packs would be the easiest route but other popular ones are wagoner, XJ, Dakota and 52" chevy packs I do believe. the XJ and Dakota packs are off centered so the will stretch wheelbase too.
jeep_boy02 is offline   Reply With Quote
Unread 07-07-2013, 11:48 AM   #3
Alex77cj7
1977 CJ7
I don't want too big of a stretch:/ how much does the xj springs stretch? They have a ton of those at the junk yard right now that I could go pick up for really cheap. Could I keep stock cj springs in the rear and go with xj's in the front or are the xj's only made to go In the rear?
Unread 07-07-2013, 12:40 PM   #4
jeep_boy02
1980 CJ7
you can do front, rear or both... Most like to chop the spring eyes off of one pair and add another main leaf. I believe the stretch is around 6 inches. keep in mind that if you do the front you'll have all the steering components to move around and deal with including moving the box most likely... MUCH easier to do a rear stretch with a comp cut of sorts and hangers mounted off of rear bumper rather than under rear crossmember due to longer springs.
Unread 07-07-2013, 12:45 PM   #5
Alex77cj7
1977 CJ7
Should I do xj rear and put the stock cj rears in the front?
Unread 07-07-2013, 12:46 PM   #6
Alex77cj7
1977 CJ7
And also should I do shackle reversal at the same time? This jeep is a daily driver.
Unread 07-07-2013, 12:47 PM   #7
Alex77cj7
1977 CJ7
Once I get the axles under I plan on wheeling it a lot more.
Unread 07-07-2013, 04:03 PM   #8
jeep_boy02
1980 CJ7
well there are many schools of thoughts on this... since its a daily driver the SRS would help with ride and streetability but some think that it tends not to work as well offroad, 6 of one and half dozen of other type of thing... being a daily driver down time is another issue and for that we get into the debate of going the easiest and least time consuming route or going fully devoted to the future needs/wants...
I would say since you are going to wheel it harder in the future you will also most likely go with larger tires too... which will need more lift... a SOA already sits purty high so at most a 2.5 inch lift spring to be used and lots of fender trimming... sooo, going to the length of cutting, moving, building/buying spring hangers and new rear bumper/shackle hangers and why not link it with coils on the cheap or just go coil overs??? ya know!
what size shoes are you running now? what do you plan? by daily driver do you mean 1: you can wheel/wrench on the weekends and HAVE to drive it to work during the week?... or 2: you have another vehicle you can/do use but you want to keep the jeep streetable because you do like to drive it around?
Unread 07-07-2013, 04:29 PM   #9
Alex77cj7
1977 CJ7
Well right now I have 33's but after the axles I want to run military 37's. this is my only vehicle. I daily drive it to work every day and wrench on it almost every weekend. I plan to one day make it just a toy and get tow rig. I really don't want to go with coils yet. Maybe once it's a trail rig toy. I should be able to clear 37's with just soa and the axle swap right?
Unread 07-07-2013, 04:37 PM   #10
Alex77cj7
1977 CJ7
Also what's best to do about shocks? I only have like 4" of uptravel before I hit bump stops so I want a bunch of down travel to make up for it!
Unread 07-07-2013, 04:39 PM   #11
jeep_boy02
1980 CJ7
OK... then I would say stick with the stockers for now... just went over your profile... I'm assuming that's it in the pic? cant really tell but doesn't look SOA from that pic... got any others? If it is SOA on stockers I would look for a set of YJ packs to swap in along with the axles... especially for the front. Lets take a step back though and find out what we're working with... And remember, PICS ALWAYS HELP!!!
Unread 07-07-2013, 04:48 PM   #12
Alex77cj7
1977 CJ7
Haha that is it in the pic but before it was soa. Here's a pic now.
It is soa on stock springs right now.
Unread 07-07-2013, 04:52 PM   #13
Alex77cj7
1977 CJ7
Unread 07-07-2013, 05:02 PM   #14
Alex77cj7
1977 CJ7
Narrow track Dana 30/amc 20. T176 with a Dana 300. Stock springs and I think shocks too. I have a set of 4" cj lift springs laying around that maybe I could use for something. Also have a serif j10 springs but they are taken apart and idk how the go back:/
Unread 07-07-2013, 05:18 PM   #15
jeep_boy02
1980 CJ7
OK, and I see you have added a winch, good start! by swapping in Yj packs you will get a better, softer ride and more articulation. The only thing you will need to change is your front shackle hangers... as it sits now... you will need to outboard the front spring mounts to mount your full width axles. as for the bump stops, I didn't need to extend mine from factory length so you may be limiting it with out the need for it... I did change the shock mounts to help mount longer and more capable shocks... on the front use shock towers from a F-250, mid 90's I think... look like these
And on the rear rather than mounting shocks to the spring plate, use a plain square spring plate without shock bolts and weld on the lower shock mount to the axle tube.
