Spring Sag issues? Front DS Rubs! - JeepForum.com
post #1 of 3 Old 10-08-2008, 10:40 AM Thread Starter
martyweir
1976 CJ7
It's a 1976 CJ7 w/ Chevy 350 swap - has original turbo 400 tranny, Quadratrac transfer case, and I would assume original axles (not sure what axles). The PO installed a shackle lift, and I have been working to correct several issues with this.
I was going to remove shackle lift, but realized that I need it due to what I now believe would be sagging springs. My front driveshaft has been rubbing on the bellhousing on extreme flex, and the Y pipe has been crushed by Ujoint.
Looking at my springs, are these shot? They look like they are sagging a bit. With stock shackles, how could the driveshaft have possibly cleared the bellhousing / Y pipe? I have a replacement pair of stock springs from a parted out CJ, but not sure if these will be any better... Should I try them? What would you do to correct the driveshaft from rubbing / Y Pipe clearance?!? COST IS A FACTOR HERE. FYI, I am doing a tub swap this winter, so I will have a good opportunity to do some suspension work then. Spring lift would be great, but I've heard not much good about some of the aftermarket springs (stiff ride), and it might blow my budget right now. Have about $300 to spend. Can I reuse some parts to reduce costs? Any advice appreciated P
martyweir is offline
post #2 of 3 Old 10-08-2008, 11:26 AM
jackstercj8
1984 CJ8
take your spring packs apart and build a heaver spring pack with the 2 sets ya got, also there should be a bump stop keeping your axle from hitting. seems your springs are the first concern atm, goodluck
jackstercj8 is offline
post #3 of 3 Old 10-08-2008, 11:52 AM Thread Starter
martyweir
1976 CJ7
Hmmm... Never thought of that...
My springs are stiff as it is (suprisingly). I would probably use the spare set and add a leaf from the currently installed set. Which would impact the flex less? the lowest spring? Can you stack two of same size?
CJ Spring ? CJ/YJ Front Stroudcreek Jeep CJ Forum 2 01-08-2010 08:20 AM
Pitman arm rubs tierod CJeep Jeep CJ Forum 17 08-23-2007 12:12 PM
Engine rubs the firewall with Drop Tran kit sircampsalot2 Jeep CJ Forum 15 02-06-2005 05:50 PM
Front spring hangers CJ to YJ Fletch Jeep CJ Forum 3 09-21-2004 05:43 PM
Front Spring jeep1 Jeep CJ Forum 1 08-26-2002 05:14 PM
