Spring Sag? How to tell! - JeepForum.com
post #1 of 3 Old 02-13-2009, 07:45 PM Thread Starter
elks96
Well before I did my lift I do not remember any CJ Lean. Now That I ahve ran my lift I am seeing my Left rear look lower and lower. How is teh best way to tell if it is due to a bad spring/sag? I am thinking measureing and comparing to the frame?
1985 CJ 7 258 bored/Cammed, MotorCraft Carb, Mallory Ignition, NP435/Dana 300, 4.5 RE Ex, 1.25 JKS Body Lift, Detriot AMC 20 Rear(detroit locker and Warn Hub Conversion), Herculined Tub, Chevy Heater Blower, 34" Swampers, Custom Rear Bumper, more to come....
1972 K5 8" lift, 36" swampers, lockers, custom paint.
elks96 is offline
post #2 of 3 Old 02-14-2009, 07:01 AM
Oily
Originally Posted by elks96 View Post
How is the best way to tell if it is due to a bad spring/sag?
I think the correct way is to remove it and take it to a spring shop along with the spring from the other side. I believe they do a tension test and measure flex travel.
What brand springs did you use ?
Oily is offline
post #3 of 3 Old 02-17-2009, 02:38 PM Thread Starter
elks96
I have RE 2.5 springs. Like I said I can see a difference be tween sides and prior to lift install I never noticed a difference. The nearest Spring Shop would require a 180 mile trip.
elks96 is offline
Leaf spring width for a 73 cj5 and spring over axle burtonboard180 Jeep CJ Forum 1 08-20-2009 08:11 AM
Spring over or under troy.j Jeep CJ Forum 22 07-31-2007 10:32 AM
has anyone used the yj leaf spring conversion for a cj and or axle over spring kits? rhino1 Jeep CJ Forum 0 08-11-2004 08:23 PM
spring over spring question and i searched flip2spin Jeep CJ Forum 3 05-21-2004 12:09 PM
Spring Over vs Spring Under Question xdeckerx Jeep CJ Forum 3 08-01-2003 10:05 PM
