Spring over suspension a good idea? - JeepForum.com
post #1 of 10 Old 10-10-2002, 05:11 PM Thread Starter
jeepin cj-5
I am looking to get a suspension system on my 73 cj-5 and i found this spring over kit with 5.5 inche of lift fpr th same price as most other say 2.5 and 4 inch lifts. Are there any problems witht he sprin over and also which is a bettr idea?
jeepin cj-5 is offline
post #2 of 10 Old 10-10-2002, 07:48 PM
CSP
All I want to know is where you found a spring over kit for a '73. I know of only two kits out there and both are for '76 and up CJ's. Only one of them is worth a darn. Hopefully you're not looking at the Full Traction kit.
CSP is offline
post #3 of 10 Old 10-10-2002, 07:53 PM Thread Starter
jeepin cj-5
Well im afraid to say that it is. I just re-read the thing in the magazine and it gives no dates but im guessin by the way u say it its a bad kit.
post #4 of 10 Old 10-11-2002, 09:57 AM
CSP
That kit is a joke. First of all it won't fit your Jeep. It's for '76 and up CJs. It does nothing to adress steering issues. A dropped pitman arm which it includes is fine on the street but does nothing but cause problems off road. Tie-rods/draglink will contact the springs in extreme articulation. Also the brackets used to mount the springs still hang below the axle tube. Getting additional ground clearance is one of the benefits of going spring over. This kit does nothing to increase ground clearance under the axle tubes.
CSP is offline
post #5 of 10 Old 10-11-2002, 11:21 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I personally think SOA is a good thing .. but only if its done right. Do the math, check the angles, get a grinder and welder and dive in. The ride and flex and height it gives outweighs any of the negative effects (missus can't climb in anymore )
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #6 of 10 Old 10-11-2002, 05:29 PM Thread Starter
jeepin cj-5
HAve you eber seen any other spring over kits for a jeep as early as a 73? I like the idea and u say it gives better ride?
post #7 of 10 Old 10-16-2002, 10:56 PM
55-willys
i would also go with the spring over. but yes, you have to find out everything about it, what kind of problems. i dont see needing a kit. you can buy the spring perches and go from there. you almost have to put your axles under the springs to see what you might run into before you start cutting. make sure your going to be able to hook your drive shafts up, and so on. id find someone thats done it and see what they had to do to make everything work right.
paul
55-willys is offline
post #8 of 10 Old 10-16-2002, 10:58 PM
55-willys
i dont know what price you were given for the kit, but on ebay you can buy some kits for around $400.00 which seems fair.
paul
post #9 of 10 Old 10-18-2002, 10:46 PM Thread Starter
jeepin cj-5
What kits have you seen on ebay? Id like to get one but i am not sure exactly what i need and i dunno if they have one for the 73.
post #10 of 10 Old 10-19-2002, 09:18 AM
55-willys
look under suspension, or in ebay motors under jeep. you might have to contact an outfit thats selling alot of jeep lift kits for other years and ask them if they have a kit for yours. i found a 4 inch trailmaster kit for a 55-75 for $275.00. also try the willys tech site.
paul
suspension Idea gotCLAY Jeep CJ Forum 3 10-14-2009 08:06 PM
suspension build idea- good or bad? mylittlecj5 Jeep CJ Forum 7 04-28-2009 07:59 AM
Suspension Idea elkhuntrwinn Jeep CJ Forum 5 11-02-2005 01:42 PM
Idea- good or bad? Tempest V Jeep CJ Forum 32 06-23-2005 10:05 AM
Good Idea? Bad Idea? SaharaMan Jeep CJ Forum 3 11-22-2002 04:58 PM
