spring over spring question and i searched - JeepForum.com
post #1 of 4 Old 05-17-2004, 06:03 PM Thread Starter
flip2spin
i got a 83 cj-8 that has a spring over on it now
i had to lift the front 2 inches more than the rear to leavle it out
its on 35s with stock springs
im planning a ford front 44 8-lug and a rear d60 shackle reversal on the front and out board the springs and 40s
my question im wanting 4inch lift yj springs will my jeep sit levle be lower in the front and will 40s fit
any help will be greatly appreited
thanks j-rod
flip2spin is offline
post #2 of 4 Old 05-18-2004, 11:41 AM
gigihurt
gigihurt's Avatar
It should sit some what level with the YJ springs on it. The CJ springs are definately higher in the rear as I just recently found out when I put my shackles on last week. It almost looks like I did it on purpose.
gigihurt is offline
post #3 of 4 Old 05-18-2004, 05:02 PM
contender54
with a spring over and 4 inch springs, 40s will fit.....especially if the axles are full-width
83 CJ7 IN PROGRESS: Warn 8274, Locked Scout D44 with 4.09s, rollcage, T18, Dana 300, Swampers, etc.etc.....
contender54 is offline
post #4 of 4 Old 05-21-2004, 12:09 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Might need to rethink that Ford front axle as it has a driver's side pumpkin compared to a CJ's passenger side drop.. also, if you're gonna do enough fabbing to swap axles and do a shackle reversal, you should be able to "tweak" the mounting of the shackle reversal to make sure you end up level (unless you plan on purchasing one of the bolt on kits then I guess you're kind of stuck with the factory height). 4" springs on a SOA are gonna put you way up there. Not sure if it will clear 40's without some trimming or body lift (I run 1.5" springs SOA and have lots of room for my little 35" TSLs). 40's might also push a Dana 44 to its limit if you wheel it. Might want to consider a D60 frontend. One thing you have going for ya is that longer wheel base. It'll help with the rear driveshaft angle (my rear shaft is only 15.5" long).
BESRK is offline
Leaf spring width for a 73 cj5 and spring over axle burtonboard180 Jeep CJ Forum 1 08-20-2009 08:11 AM
84 CJ spring question Houdini Jeep CJ Forum 2 07-05-2007 03:51 PM
Spring Question Fropleyqk Jeep CJ Forum 4 02-27-2007 08:01 PM
has anyone used the yj leaf spring conversion for a cj and or axle over spring kits? rhino1 Jeep CJ Forum 0 08-11-2004 08:23 PM
Spring Over vs Spring Under Question xdeckerx Jeep CJ Forum 3 08-01-2003 10:05 PM
