Spring over - JeepForum.com
post #1 of 16 Old 06-03-2013, 11:20 AM Thread Starter
kp33
1978 CJ5
Spring over
was told by a stranger I could do a spring over ot get a bit more height on my 78 cj, no clue what that is or how to do it. Does it work to get a bit more height?
kp33 is offline
post #2 of 16 Old 06-03-2013, 11:25 AM
jeepwhore
It nets about 5" of lift, isn't the easiest to make work on a CJ5 and to do it right can cost as much or more than a regular lift kit.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #3 of 16 Old 06-03-2013, 11:27 AM Thread Starter
kp33
1978 CJ5
he didnt mention that, thanks.
kp33 is offline
post #4 of 16 Old 06-03-2013, 11:38 AM
jeepwhore
If you only want a bit more height you'd be better off with a quality 2.5" lift kit.
:-D
post #5 of 16 Old 06-03-2013, 11:40 AM
sanctified
A spring over refers to installing your springs from the standard location under the axle to sit on top of the axle. It will give you height but there are other things that will need to be adjusted to ensure your rig runs like it ought to. The PO of my CJ7 did a spring over (SOA) and didn't adjust the pinion angle right which caused me to break u-bolts and joints like crazy last weekend at Moab. I didn't realize it was that bad before I went down and broke 5+ ubolts when I got on some steep inclines. Search for SOA and read up about it before you jump into it. It can be a really cheap way to get lift but in all honesty unless you do it right you rig will break or drive like garbage.
My springs are toast and I am pretty much decided to go back to SUA with a 2.5" or so lift. I need to look into it more but I know that you can put YJ springs on a CJ with a little work and they aren't very expensive. I think they are about $120 or so per spring.
EDIT: looks like I was too slow in my response.
2013 JK (see info on left)
SOLD: 1983 CJ7
Utah Jeep Crew #178
sanctified is offline
post #6 of 16 Old 06-03-2013, 11:42 AM
82JeepCJ7
1982 CJ7
They flex better and ride better than a high arch leaf spring kit. They offer a lot more ground clearance under the axles. That being said, unless you have some fabrication and welding experience, don't attempt it. There are many factors to consider. Front caster angle, rear pinion angle (will require a DC rear driveshaft) etc. I did mine in 11hrs start to finish, but I had been a welder/fabricator for years at that point. If you do the work yourself, you can come in under what a lift kit will cost. Plan on purchasing a drop pittman arm. Consider fabricating a torque arm for the rear axle.
Pics of mine.
Bottom view
(Can see traction bar in the rear)
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #7 of 16 Old 06-03-2013, 09:09 PM
Alex77cj7
1977 CJ7
Did mine not long ago and love it!
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
Alex77cj7 is offline
post #8 of 16 Old 06-03-2013, 09:57 PM
spottedfrog
1979 CJ5
Is this on NTs? If so do you have an overall pic?
Pics of mine.
Bottom view
spottedfrog is offline
post #9 of 16 Old 06-03-2013, 10:06 PM
Alex77cj7
1977 CJ7
Mine are!
post #10 of 16 Old 06-03-2013, 10:36 PM
82JeepCJ7
1982 CJ7
Wide trac axles
post #11 of 16 Old 06-03-2013, 10:47 PM
Luckyirish2440
Pics of mine.
Bottom view
What type springs are those? Also, where did you connect your torque arm to(jeep side)?
Luckyirish2440 is offline
post #12 of 16 Old 06-04-2013, 12:15 AM
82JeepCJ7
1982 CJ7
Stock CJ springs. The torque arm is attached to the cross member by the T-case with a shackle. Ill post pics when I get home.
post #13 of 16 Old 06-04-2013, 12:35 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Do yourself a favor......don't just read this - study it til your eyes bleed.
http://mysite.verizon.net/res108eps/...ion-basics.pdf
Joe Dillard is offline
post #14 of 16 Old 06-04-2013, 12:57 AM
82JeepCJ7
1982 CJ7
Upper mount.
post #15 of 16 Old 06-04-2013, 09:51 AM
Luckyirish2440
Upper mount.
Does the shackle hit your transfer case at all?
